A company called custom caprers might be abill to help I have no connection with them other than getting sum bits for my verry old vanBeen looking for a spare wheel lately then remembered someone mentioned a breakers yard that has motorhome bits an bobs but can't find the post so if anyone can point me in the right direction that would be great. TIA.
Nice to see you back billA company called custom caprers might be abill to help I have no connection with them other than getting sum bits for my verry old van
Bill
16" 5 stud 71mm centre'sWhat size wheel are you looking for?
that's what I was told to measure by the wheel shop in Manchester 71, light 78 heavy centre of wheel stud to centre of adjacent one which was 71 and a midges di*k, have they told me wrong and have you got a spare one knocking around ta.That's narrow. Ducato lights are 115mm, the heavy being even larger.
photo of my wheel, that's where I was told to measureThat's narrow. Ducato lights are 115mm, the heavy being even larger.
Have you looked in the classified adds on the forum there were some on there very recently?photo of my wheel, that's where I was told to measure
yes only 15"Have you looked in the classified adds on the forum there were some on there very recently?
I've got a steel spare wheel for a light chassis with a brand new 225/75/16 tyre but my problem is that it is eating a chunk out of my payload so I am thinking about selling it and going back to relying on my "tube of goo". It cost me £145 eighteen months ago. PM me if you are interested in making an offer.that's what I was told to measure by the wheel shop in Manchester 71, light 78 heavy centre of wheel stud to centre of adjacent one which was 71 and a midges di*k, have they told me wrong and have you got a spare one knocking around ta.
I've got a steel spare wheel for a light chassis with a brand new 225/75 tyre but my problem is that it is eating a chunk out of my payload so I am thinking about selling it and going back to relying on my "tube of goo". It cost me £145 eighteen months ago. PM me if you are interested in making an offer.
thanks but need the light oneI will have a brand new heavy 130pdc steel wheel with a good used tyre on soon, I just need to the get the tyre off it and fitted to my other spare (an alloy)
Don't do it. Sure as eggs are eggs when you need it the tube of gunk isn't going to hack it and even if it does most of the tyre guys won't even touch it. You'll be buying a new tyre.I've got a steel spare wheel for a light chassis with a brand new 225/75/16 tyre but my problem is that it is eating a chunk out of my payload so I am thinking about selling it and going back to relying on my "tube of goo". It cost me £145 eighteen months ago. PM me if you are interested in making an offer.
Hi dunnah01, I was told to measure half way between two centres 71 for the light chassis or 78 for the heavy chassis, by the Wheel shop , if you have a look at Newfi's post the calculator tells you to measure the two points and times it by 1.7012 which gives you 120 ,so what's the best way to go as I will need one it the next 2/3weeksIt might be worth re-checking your measurement of the bolt centres. 115mm PCD would be just over 67mm bolt centres and 130mm PCD would be 76mm so your 71mm is sort of in-between
Hi Ex caravantugger , was told to measure between the studs but what you have said makes sense , but as said previously Newfi's post show how to measure and it is between the studs then x itI think that what the OP has been asked to measure is not the PCD or the distance between studs but the size of the centre bore of the wheel which is 71.1mm for light chassis and 78.1mm for heavy chassis. Likewise the light chassis uses 14mm bolts and the heavy 16mm bolts. Mike
