Boxer 2002 1.9 Turbo has blown a big hole in the bottom of my engine......
caretaker bob
Peugeot Boxer 2002
Ok,
I have little to offer this forum at the moment as my knowledge is zero on campervanning and mechanics. The van I have is a Boxer Vivago 2002. It started blowing black smoke, lost power and upon getting to my home, the bottom blew out of my engine with bits of casing and oil everywhere. After containing the slick, I realised that my van was in a bit of trouble.
I have friends who tell me there are plenty of 1.9 engines out there, but I'm unsure which ones will fit. I have some questions if you can take the time to answer, I would be grateful.
1. Am I able to get a bigger cc engine to slot in or do I have to change lots of other stuff to make it fit?
2. if no to the above, how can I find a compatible donor engine that will slot straight in.
The engine I have access to is from a 306 but it seems to have lots of wires going to the front of the engine where mine doesn't? (be gentle)
below is the donor car with the red around the electrical bit and the other my vans engine....
thankyou in advance
Bob
Excel Engine Services
00
Home > Vauxhall Vivaro Engines
VAUXHALL VIVARO ENGINES
Remanufactured Engines & Engine Fitting​
We provide a complete service to repair your Vauxhall Vivaro supplying you with a replacement remanufactured engine to get you back on the road. Engines are available from stock and are ready to be shipped with fast delivery.
Alternatively we can take on your whole vehicle, working on it in-house to fit a new or remanufactured engine and any parts needed.
We are experts in the remanufacture of Vauxhall Vivaro engines with a fully equipped engine rebuilding workshop.
See our full range of Vivaro engines ->
Remanufactured Engines​
We are professional engine remanufacturers offering an engine machining and engine rebuilding service from our fully equipped workshop, using the latest brand leading machinery including Serdi, Berco, Scledum and Kwik-Way. This enable us to provide total accuracy and a quality finish at all times.
For many years we have been successfully supplying remanufactured Vauxhall Vivaro engines, short motors and cylinder heads throughout the UK and into Europe.
We use only the highest quality branded parts (to OEM specification) and genuine Vauxhall parts, in the process of remanufacturing Vauxhall Vivaro engines.
Engine Fitting Service​
We provide an engine fitting service for all Vauxhall Vivaro Vans and Cabs
00
Home > Vauxhall Vivaro - Engines
VAUXHALL VIVARO - ENGINES
A range of professionally remanufactured Engines and Short Motors for Vauxhall Vivaro vehicles.
Vauxhall Vivaro Engine Codes​
1.6 CDTI (1598cc)​
R9M408, R9M413, R9M 408, R9M 413
1.6 CDTI BiTurbo (1598cc)​
R9M450, R9M452, R9M 450, R9M 452
1.9 DI (1870cc)​
F9Q762, F9Q 762
1.9 DTI (1870cc)​
F9Q760, F9Q 760
2.0 CDTI (1995cc)​
M9R630, M9R780, M9R782, M9R784, M9R786, M9R788, M9R 630, M9R 780, M9R 782, M9R 784, M9R 786, M9R 788
2.0 CDTI ecoflex (1995cc)​
M9R692, M9R 692
2.5 DCI (2464cc)​
G9U630, G9U730, G9U 630, G9U 730
Earlier engines available upon
F9q760, is the 1,9 turbo fitted up to 2005.
OPs van is a peugeot boxer I think
I've no experience of swopping engines, but I think for simplicity, you'd be better making a straight swop with the same engine and the one in the car is almost certainly a different engine.
Excel Engines above seem to know what they're doing and could be you best option ?
Good luck sorting it out, let us know how you get on 👍
I use this guy knows his stuff and probably has one
Cheers James
Funny story is I knew one of the XUD designers a couple of decades ago it was great to be able to ask Him all about the engine he was involved with designing.
Cheers James
Try Manda campers on the number below. They are Peugeot boxer engine specialists and keep second hand and recon units in stock.
Black smoke would indicate turbo failure. Yes it is a bolt on item, however, if it had imploded bits may have made it into the engine and caused carnage.
If you read the op original post that is what has happened🙄
Thank you for that, I was trying to explain that it may just be the turbo, would account for casing and lot of oil. If the bottom or sump of the engine had blown out all the oil would be gone and the engine would have seized long before he could have parked up. If the engine has an intercooler the damage may just be a replacement turbo and a clean up. Vast saving over an engine replacement.
