Black tank an option? (2 Viewers)
19,365
30,302
I am sure Michael is right as it’s not standard so must be optional.
Aug 5, 2018
1,567
3,513
a
Having had to deal with my bosses Merican RV black tank, I think I'd rather stick to the cassette.
Theonlysue
6,104
7,383
As Executive 50th an
Not long enough!
Easier to empty cassette.
Black tank will need specific emptying places.
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
I only have the 2017 price list but they showed 2 black tank options, E898 for 130 litre or E1253 for 160 litre.
As to the tank management we had the 160 litre tank in our Flair that would easily last 10 days and we do not use site facilities. The dumping procedure for a Yankee is indeed more conspicuous as they have 4 inch pipes and very often a non macerating toilet but my Flair had 38mm pipes and a macerating toilet and just dumping where you dump grey is easy with a 10 day margin to work with, or even easier on full service pitches. My Morelo has a 250 litre black tank with a cross over pump from the grey to the black if you need the spare capacity. I will not get into the debate again about where you can dump it in European sewerage systems amply covered in the past.
Michael
TheAleMan
Sep 21, 2007
1,626
13,690
Kings Ripton, Huntingdon
RP Rebellion 2 2024
Ah, found it... 160 l fixed toilet tank (only available for models 920 LE, LF, LS) including ceramic toilet bowl
"Black tank with cross over pump", that's the system we want to go for. we are going full time so don't want the hassle, albeit a small one, of emptying the cassette every couple of days.
Thanks for the help guys. (y)
Jul 29, 2007
6,551
39,664
Ipswich
RV and PVC
30 years
I carry a tote tank, so in the event I can't dump even with my macerator and 50' of hose I can fill that and take it to the dump instead, in 14 years of owning the Winnie I have used it once.
I am not so sure about using a cross over pump through as its the grey water which flushes my 3" pipe out after dumping the black.
TheAleMan
Sep 21, 2007
1,626
13,690
RP Rebellion 2 2024
But still needs to be flush ground dump yes Olley?
Jul 29, 2007
6,551
39,664
Ipswich
RV and PVC
30 years
Not on the Brave my outlet is possibly 2 feet or more of the ground inside the locker, its a heated double floor so the tank is above the frame rails.
This is when we lived for a year on a site with mains drainage.
eddie
8,157
41,271
Taunton Somerset
RV
since 1989
My friend has a little plastic pot he runs out to change every morning, Jeffs poo run
Rain or shine, boiling or freezing Jeff runs across the campsite with his little pot of poo
Every few days, about 10 - 12 i drive over a manhole or a dump point, pull a lever and all the poo disappears, then i pull another lever and all the grey water flushes everything and then I'm done
A few seconds at most
And, if I need to, i also have a little plastic pot and can empty my black tank via another valve so the best of both worlds
Jul 29, 2007
6,551
39,664
Ipswich
RV and PVC
30 years
I think your probably right, I believe from memory it holds 15-20 gallons so over 75lbs, can't be sure as it must be ten years since I used it. It's sitting in my roof box with a similar sized drinking water tote, now that has never been used. :roflmto:
