best ideas for a camping shower (1 Viewer)
BreweryDave
3,495
10,542
Alvor, Algarve
None now!
Stay in the uk and wait till it rains, (you won’t have to wait long) then go out in the rain, and have a pina colada at the same time ;)
Popeye
Sep 5, 2011
7,926
86,461
edge of New Forest
Frankia Platin Plus
On and off since 1983
Besides the shower inside the van I also use a solar shower which I used on the yacht on hot days and a 12 volt one for washing down our bikes or shoes or wet suits / sandy feet.
Mine is like THIS ONE but with a straight forward cigar lighter connection which I plug in almost anywhere on the van, Garage or through a window.
This one is almost even better as it has a rechargable battery so you could use it away from the van even down on the beach.
Rechargable Shower dip it in the solar shower bag first thing in the morning heated elsewhere/cooker etc
tony dellar
63
32
I lived in a house in greece for years no electricity , 3/4 bucket of water , boil a gas kettle pour in to required temp use a saucepan to wet down wash and rinse off , pour the remains of bucket over your head , job done ! The house had a well so had to mind the water , bucket job uses around 9 ltr .
Shrimp
May 27, 2015
3,988
33,497
Bedfordshire, UK
Hymer B584
Long time
Years ago, when we lived in a house, we re-vamped our house bathroom, ripped out the bath & put a shower in.
Whilst all this was being done, we did it our selves evenings & spare time, so we used the Solar showers (we had two) filled with hot water from the tap. We hung them in a sheltered corner of our garden and showered out there! Worked a treat.
Luckily our garden wasn’t overlooked by any neighbours!
Tip: we’ve replaced the tiny shower head we have one our remaining Solar shower with a slightly bigger one-works better.
Shrimp
May 27, 2015
3,988
33,497
Bedfordshire, UK
Hymer B584
Long time
Just looked at Popeye’s post.
The Libberway Portable Camping Shower look like a good idea as you could use that in the toilet tent!
Use a bucket of hot water tho! :D
May 19, 2016
123
277
Lancashire
VW T30 hitop conversion
Bit off piste I know, but I've just bought a MudDaddy to wash off the dogs. I do have a shower hose from back of van but only cold water. This way I can heat water and use after beach trips etc. States water stays hot for couple of hours. Holds 5 litres but works under vacuum pressure. I haven't tried it yet but I'll probably try it for me too at some point. (Disinfecting between washes ).
32,669
66,630
Don't think 5L would be enough for a 'human' especially if washing hair and the flow looks very low ... however the feel of the brush might be rather nice! :D
Badknee
7,408
413,017
notloB
Vantage Neo
Living the dream.
We used exactly the same as @Popeye only home made out of a submersible I had in stock.
We had a baby bath we put a kettle of hot water into and cooled to a comfortable temp. Stood kids in bath and showered them, brill bit of kit.
bfb
125
52
Aldershot
Hymer A Class
When I was using my VW Caravelle I bought a toilet tent from my local camping stockist and hung it on the open rear door and bought a battery shower from RING at Halfords. 25 ltr water container. Fill with 50/50 hot/cold water gives great shower twice. Used it for 4-5 years then bought a motorhome so now no problems.
17,635
43,366
I have got a pump up shower system that we bought 20+ years ago to use in double toilet tents. just fill up to the line with hot water and pump up. then press the button on the shower head for a good shower. if the power of the jet drops, just pump the handle again
its now relegated to in the 4x4 for washing dirty dogs after a muddy walk
Popeye
Sep 5, 2011
7,926
86,461
edge of New Forest
Frankia Platin Plus
I have just found mine whilst clearing the Garage prior to Hab Check and it turns out it is FIAMMA. It has it's own waterproof bag for the shower head inside the draw string carry bag. Mine is in Grey.
patricia the newbie
Jan 5, 2017
427
400
brinklow warwickshire
Romahome duo hylo
since 2016
I've been looking at a pump up system, my friend said the advantage of that system is your not relying on electricity in any way Ive been looking at the Hozelock system . I wondered if any of you have tried it or something similar ?
32,669
66,630
The problem with pump-up systems is that you're not going to get the pressure you want along with the length of time you need for showering, even with the quick shower method, so you'll either end up with a very low pressure shower that might last long enough, or you'll end up with a good water rate but it'll stop whilst you're still soapy! Having used manual pump system sprayers etc I certainly wouldn't want to rely on one for a shower, for washing hair or something like that they'd be fine but then you can use a washing-up bowl and beaker!
17,635
43,366
as above, i have exactly that fitted with a trigger release shower head. works great but limited to 7ltrs
