Beeping noise on roundabouts (2 Viewers)
May 4, 2015
1,244
1,643
North Yorkshire
since 2000
In between lockdowns we took the MH for a short run along the bypass, at each roundabout something beeped. As it was completely empty we thought it was a warning that we had no water in the tanks. We half filled it with water yesterday and we have been out for an hours run. It's still bleeping. I have just checked all the cupboards and found the carbon monoxide alarm laid on a shelf on its front. Hopefully it has slid along the shelf on roundabouts and caught the test button. I have slid it along the kitchen floor and it beeped so hopefully it's problem solved.
Next trip is three nights at the Crown in Mickleton at the beginning of May so there will be a few bends to test it out.
PP Bear
7,842
28,930
Kent, UK
Auto Trail Dakota SE
53,656
150,823
Are you sure the sound is not coming from the front end. We had the same on our last van, beeped on every roundabout after about the 10th time I notice a message flash up on the dash but so fast you couldn't read it. Finally managed to read it after another half a dozen beeps, low oil level.
bigtwin
5,253
9,969
Derby
Concorde
Traction control coming on as the van sways due to the force associated with rounding the ‘bend’ thus unloading the inside wheel, causing momentary wheel spin. 🤔
Ian
Casper46
May 4, 2015
1,244
1,643
North Yorkshire
since 2000
No, it’s from the rear and I checked the oil level before we left home. I was going steady - speed wise. There are so many speed checks locally, besides which I do try to observe speed limits. It’s difficult due to the rubbish position of the Fiat speedo, I can get to within a couple of mph without needing to check but speed traps don’t take that into account. I have a heads up display but as our last journey in November was return from France I forgot to change it before today’s trip.
Oct 8, 2014
1,544
4,565
Todmorden
Compactline 143
I'm a newbie and always will be. You never know it all.
I have had exactly the same experience when the oil seal went on my filter.
Apr 30, 2018
1,996
4,428
Mid Suffolk
Adria Matrix 670DC
Motorhoming since 2018.
I had exactly the same problem, it turned out to be the low level warning for the cold water tank (habitation not engine).
Jul 11, 2020
543
1,440
Southampton
Benimar Tessoro T486
Since August 2020
I had a loud beep when I drove Harvey for the first time after lockdown - once every few minutes from somewhere behind me. It was irritating. Then on parking, climbed in the hab door and it beeped again. Found the culprit - old battery in the smoke detector.......durrh
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
I get a bleep on roundabouts and it is the tyre pressure warning unit, I set that pressure drop/rise too close and as we go around the corner the increase in pressure is greater than the one that I set and it goes off, I will do it again sometime
Casper46
May 4, 2015
1,244
1,643
North Yorkshire
since 2000
I don't think that we have a tyre pressure warning on ours, unless it's a Carthago standard fit and we don't know about it.
But thanks for the idea.
