Why?If 2 or more batteries are connected to same charger they must be same age ,same amp hour
when you connect more than one battery together they BECOME one battery..If 2 or more batteries are connected to same charger they must be same age ,same amp hour same type i.e. Lead,gel,what ever. That is because they need to be charged at same rate from charger as if there one battery. mix them up and they won't charge up to full capacity
thats incorrect any sizes can be put together, charger just sees them as one batteryIf 2 or more batteries are connected to same charger they must be same age ,same amp hour same type i.e. Lead,gel,what ever. That is because they need to be charged at same rate from charger as if there one battery. mix them up and they won't charge up to full capacity
Why?The charger will see different capacity batteries, linked together in parallel, as one battery. However, this means that neither battery will be charged correctly. The smaller capacity battery will be overcharged (not recommended) and the larger capacity battery will be undercharged.
A charger does not and cannot see the capacity / size of the battery.The charger will see different capacity batteries, linked together in parallel, as one battery. However, this means that neither battery will be charged correctly. The smaller capacity battery will be overcharged (not recommended) and the larger capacity battery will be undercharged.
No they don't as somebody else has said one will be overcharged and one over charged why do you think they bother putting capacitys on batteries in first placethats incorrect any sizes can be put together, charger just sees them as one battery
Best practice for best performance if and old battery starts to fail connected to a new battery in parallel it won't charge properly so u don't get a good outWhy?
every 12v battery is 6x 2v batteries joined together but you still get 12v not 2vNo they don't as somebody else has said one will be overcharged and one over charged why do you think they bother putting capacitys on batteries in first place
I think you could have put that a little differently. The reason it sometimes seems hard work to get a message across is that many members see conflicting advice from so called expert professionals and their websites and it becomes hard to sort the wheat from the chaff. The positive side to that is that it promotes healthy debate and ultimately an increase in knowledge.Its like educating pork on this forum sometimes what with batteries and climate change posts?
That wasn't what I queried.Best practice for best performance if and old battery starts to fail connected to a new battery in parallel it won't charge properly so u don't get a good out
I nearly spat my chinese takeaway outWe need negative side too or the whole thing won't work ? ? ?
Must be getting old, it's taken me all this time to work that out. Very good.We need negative side too or the whole thing won't work ? ? ?
Why do they need to be the same capacity, as I outlined in red in my original question.
So the all the individual cells of 2 volts charge at same rate and discharge at same rate, larger amp batteries have bigger cells of 2 volts and smaller amp batteries have smaller cells of 2 volts as an example if u got a small can and a large can both filled with water to the top and the same size hole drilled in bottom which can do u think would empty first?
So if both cans were the same size ,same size hole drilled in bottom filled to the top they would both empty at same rate and recharge at same rate which is better for the charger ,don't get me wrong you can have a small battery and larger battery it will still work ok but not best practice when your trying to get the best from discharging and charging in my experience hope this helps
It’s just best practice if u can use the same size but when in the desert u use anything !They don't though because of simple manufacturing tolerances, ALL battery cells are not equal. As Eddy mentioned, there have been starter batteries linked to "god knows what" since campervans have been invented.
