Hi I don't know what I did, but I was trying to post a new thread about the battery Isolating Switch but didn't get chance to ask the question, it just posted automatically. Anyway the question is what is the purpose of the switch surly by simply turning off the power at the control panel will isolate the vans electrics anyway.
And if I turned the switch off will it prevent the batterys being charged via the solar panel or the engine alternator.
I think if it was a 'face on' shot the terminal and bolt are some distance apart.The cable / terminal on the right in the top picture is dangerously close to what looks like an earthed bolt - if so, I do hope that cable isn't live.
Being a non subscribed member it may be hidden from you.Hi there, I don't know what I did, but how do I find the Tech/Mech section?
Optical illusion.
Yes it is the mounting bolt, which places it equidistant from both terminals.The bolt looks suspiciously like the mounting bolt in the third picture.
Hope it is an optical illusion.
No I didn't either, sorry...Thanks for that Papua John didn't know that.
Obviously total isolation.I'm still not getting why the switch has been fitted what is the purpose of it
In the OFF position the switch will isolate the starter ( assuming it's the starter battery ) or the hab' battery from the rest of the hab' / vehicle circuitry & will / should prevent discharging from a parasitic drain & charging from the alternator / solar, depending on how the solar is connected & could be used as an anti theft device, as even with the ignition key the vehicle won't start, but it's a bit obvious placed where it is.
That bolt clamps to the metal seat support, which will be earthed. I think we're worried that it's very very easy to catch it with a spanner if you were undoing the bolt to maybe add another circuit.The cable / terminal on the right in the top picture is dangerously close to what looks like an earthed bolt - if so, I do hope that cable isn't live.
That's right it is a mounting bolt. It has been professional fitted though (I think )
See what you mean Super Mike but it was fitted when I bought the van so no refund possible! !
