Bailey autograph 79-6 HELP ME (2 Viewers)
Iammaggie
5
Owned my first MH for 3 weeks now and have just done 2 weeks in France . Couple of issues if anyone can help out.
How do I solve the issue of the dinette seats sliding out constantly.
The window clips have all but one fallen off
When lights are switched on all 10 lights round the van switch on and have to be pressed individually to switch them off
How do I turn on the light under the kitchen units. It’s puzzling me as I have seen the light on twice now but have no idea where the switch is.
And why does my water tank over flow instead of auto cut off.
Oh and I have a spare piece of bed which I have no idea where it goes ‍♀️ other than these minor issues what a great little beaut our DORA is
Whippetgood
26
32
Hi,
To stop the cushions sliding I taped self-adhesive Velcro hook strips to the bench slats and interleaved the split cushions with the anti-slip mesh you use under rugs.
If you mean the window clips that hold the mesh and concertina sections together then I've had to replace a couple but they're not essential - you just slide the sections up or down as normal.
My lights also do that and I'll probably fit an isolator switch somewhere to switch them off - because they are touch sensitive there is a constant drain on the battery even when they're off so I want to make sure that they are only on when I want them.
The strip light above the sink is touch sensitive - just touch it on the body at the extreme right of the light and it will go off and on - keep trying until you find the switch spot.
Jon
Whippetgood
26
32
Also - there is no auto cut off for the water - it will just overflow and if you post a picture of the spare bed piece someone will point you in the right direction.
Jon
I
Iammaggie
5
Thank you Jon. I need to fix the seats as a matter of urgency as the kids keeping sliding from the seats. I wasn’t sure if it was something I should attempt myself or take back to my dealer as my MH is brand new same with the lights.
old-mo
Extra Special
16,343
93,692
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
I would take it back to the dealer... :nod: :nod: :nod:
If you start messing about with things it may invalidate your warranty... :rolleyes:
Sounds like a poor hand over job when you collected it, to me.. :(
I
Iammaggie
5
Great news Jon, found the touch strip on the light
1,044
999
Cumbria
Pilote P740FC
Definitely take it back to the dealer!
If the window clips are the same as the ones we had on a 2013 Approach 740, they break with monotonous regularity - Bailey’s spares website sell them for a crazy price for a plastic clip (from memory about £4.50. Each. Plus postage.) Suggest you get replacements from your dealer under warranty.
I
Iammaggie
5
My spare piece
I
Iammaggie
5
Dazzler1969
134
130
Leicestershire
S&L Atlanta PVC
Hi,
We have had ours for a couple of months now, been out 6 times and listing the issues ready for a single return to the dealer. The spare cushion parts are not listed as being used in the hand book but it looks like they changed the style mid 17 early 18, they are infills for the front bed and the rear bed! Although not very good and certainly nowhere near level ish..... I ended up contacting a very difficult to get hold of customer services team at Bailey.
We have the dreaded wind noise in the cab sunroof, driving me up the wall and was told it was an issue on earlier models and not mine
Just on our way from Isle of Wight to St Ives for a week then back to dealers.
Enjoy your new toy
Darren and Lou
WynandJean
6,670
3,303
West Midlands
Bailey Autograph 682
I find the problem with the downlighters gets more irritating with time (we have the 68-2 so only six of them) More to the point it is Bailey's attitude to it that I find annoying. When I raise the problem of them coming on by default they say "that's how they are and you have the option to turn ALL lighting off at the control panel so it's not a problem." or, "Most of our customers are happy with it as it is" (I have yet to find ANYONE who is. The dealer just follows the same line as Baileys and refuse to see it as a problem. I'd be interested to hear from all these customers that Bailey's say like it the way it is, especially when they forget to go to the rear of the van for the umpteenth time to individually turn off all the lights that they didn't want on in the first place. :madder:
Wyn
79
65
St Albans,
Bailey
The window clips are glued in, had three come off and a bit of super glue works ok.
The cushion is for the Dinette bed, goes in the middle.
Still haven't sorted those sliding seats out yet. Not helped by the seat belts protruding. I think the latest models have a cut out in the cushions to avoid catching.
Wind noise is the wrong size rubber sealing, need to get a larger size fitted.
Lights according to Bailey are designed that way! In dinette a simple switch on the bed will switch off the two lights hidden by the pull down bed. the 4 under the bed switch off by the TV. Two underneath the TV are easy to just touch off. The 6 in the back are just a pain in the A...
All in all a brilliant Motorhome, just don't shout to loud or all those foreign owning motor homers will get jealous and want one.
53,432
150,019
I can see the lights thing is annoying but why is it such a problem if it only happens when you turn the control panel on. I don't think I've ever turned my control panel off on my van apart from when working on the electrics.
138go
3,276
14,613
Carthago 138
Since 2001
NCC insist that all electrics in the Habitation area are turned off or starting the vehicle turns everything off. Overseas vehicles do not have this particular feature :) which is why we can travel with the heating on when it’s cold and leave the control panel on.
53,432
150,019
NCC insist that all electrics in the Habitation area are turned off or starting the vehicle turns everything off. Overseas vehicles do not have this particular feature :) which is why we can travel with the heating on when it’s cold.
Forgot about the stupid NCC.
Should be easy enough to disable or bypass the relay.
lozbou
125
56
north yorkshire
low profile
the lights are designed to come on although i believe they can be fitted with an isolator to stop it.? personally i don't find it a problem.
Kevan
1,097
968
Kent and south west France
van conversion
30 years caravan/motorhome
My last two vans have had Alde heating never changed the fluid in 8 years, just top up when needed, might not be the correct way but never let me down. just saying(y)
Camdoon
1,531
2,808
Adria Matrix Supreme
Our Adria is NCC approved and the electrics do not go off when the van is started.
Camdoon
1,531
2,808
Electrics on and door on r/h side - bust a few myths or I am asking for my money back :)
55149
Hi Maggie, picking up a new Bailey 79-4 on Monday so your post timely on things to watch out for. I hope you've got it all sorted. If anything else comes to mind that you wish you'd asked the dealer about then I'd love to know.
Best wishes
Colin
scbunurse
84
52
Inverness
Test driving tomorrow !!!
Hi - a little late joining in here so hopefully you have sorted your problems. We have had a 79 6 for just under a year annd its just gone back to the dealers to get some of the issues sorted hopefully. The whistling rooflight is a known problem and they are going to fit a thicker seal. The lights drove me crazy as well, mainly the ones above the drop down bed as I'm not as agile as I once was and you had to be a contortionist to get to the one nearest the cab. We had a switch fitted on the outside of the bedframe opposite the tv which switches those two off, The rest are easily accessed so not really a problem. We do a lot off grid so try to turn anything off that's not really needed. The slipping seats are a more serious problem and we have already had one of the grandchildren sustain a bump when they slipped off when fortunately we were stationary. I have been offered more velcro but holding out for the new design seats. They have to go back to Bellfield apparently so may take seveal weeks - some of them seem to be collapsing at the edge as well. We have found the rear bed to be very uncomfortable with the jigsaw of cushions but have bought a 3" thick foam topper which has solved the problem. If we are on our own we tend to leave the bed made up but if we need the rear area it rolls up with straps round it and goes in the shower. The revering/brake/indicator light surrounds are rusting and are also being replaced. Overall though we love it and it's perfect for us. Hope you enjoy yours as much as we are.
55149
Hi, thanks for the update.
We’ve not used the MH as much as we’d of liked due to a family illness taking up time. But when we have been out it’s great. This year should see more usage. I’ve worked through most of the problems.
Main pain were the white plastic bushes retaining the rear sliding bed frame to the base. They are attached with a self tapper into the bottom of the bed frame and it’s a weak design. Kept finding them on floor of boot. Ended up drilling through top of bed frame and bolting them on through the whole metal frame.
Only current issue is boot door seals. Wher they go round the curved corners of the doors they have raised up proud of the door profile and stick out.
Had to glue on the front window concertina screen handles as they kept falling off.
Window blind lifting strings come undone occasionally.
Other than that we seem good.
11,727
13,706
Are the slipping seat bases on the seats that are used for travelling and have the seat belts on them. In that case that is a design fault that must be rectified as it renders the seat belts dangerous. In an accident the seat base will move forward and the person sitting there can tunnel under the seat belt.
138go
3,276
14,613
Carthago 138
Since 2001
Think a lot of these problems are just down to poor design and cost cutting. Looked at one at a Dealers last weekend and the small table that is attached to the side as you go through the habitation door was hanging on with two screws. The other side had just pulled out including the bracket. There were just a couple of small wood screws in a piece of lightweight ply trying to hold a table. As for the seats moving they have to design them so you can move them around because of the crazy way they expect you to make beds up. A piece of thick foam that is designed to be sat on for a few hours is hardly going to make for a good bed. Couple of strips of the very wide velcro ( Not the thin stuff ) would help but you need to stitch the velcro to the back of the cushions and have long strips..
792
1,157
Lichfield, UK
As Bailey have done crash testing and the van needs to be approved by C& U regulations before production I would imagine that both the seat belts and passenger seats passed the requirements by law,I may be wrong!
11,727
13,706
I don't think that Bailey would have done any crash testing. That is usually done by the chassis makers Fiat on standard cab chassis as sold to Bailey and all the other converters. It will not include the stuff that Bailey adds.
792
1,157
Lichfield, UK
According to their website it's done at Millbrook in Bedford and they are on Peugeot front ends with an Alko chassis not a normal van chassis that some 'converters' mainly continental use.
