B544 White diesel flap (1 Viewer)
Apr 11, 2015
8
5
Kidderminster
Hymer B544
9 years
Hi All. I need a white diesel cap flap for my van. It’s not the actual filler cap but the square white plastic lift up part, that covers the cap. Travelworld sent me one for £115 but it was the whole diesel cap and neck part, which I didn’t need. It’s just the simple lift up flap. I’ve searched tirelessly on the web to no avail. I know it’s quite a trivial part but still, one I’m looking for. I can find electric and water point flaps but not diesel. Any ideas please? Kind Regards
Sep 28, 2015
2,018
2,615
Kingston upon Hull, East Yorkshire.
Hymer B544
2001 Caravans 2011 Motorhomes
I’ve got the same problem due to the little plastic clip breaking and the stupidity of Hymer not using magnetic screws to fix the unit.
It constantly flapped in the wind but I’ve got around it by replacing one of the four fixing screws with a steel one and gluing one of those strong mini magnets over the original very weak ones on the flap.
I’ve not been able to find the flap available without the whole unit.
Lenny HB
53,448
150,063
On the coast in West Sussex
Hymer B678 DL
You can definitely buy them separately they come with a new hinge pin and spring. The one on my last van went dealer sent me one.
The newer ones with the magnets are just as bad the magnets rust away.
Does it matter if it has a tap symbol on it, if it does worry you remove it with a mild solvent or put a label on it.
This may be the same you need to check as there are a few manufacturers. Probably easier to remove the water one to check the manufacturer.
https://rover.ebay.com/rover/1/710-...0001&campid=5338547443&icep_item=223727569444
3,682
80,882
Alentejo,Portugal
Hymer A Class
Since the '80,s
I also have the same problem but the edge of the surround is damaged also.Previous owner had a scrape there and took it off.I removed it and the neck but from memory it was all in one piece,mine is grey but wouldn’t be too worried if was white,have lived with it but would like to replace,looks ghastly.
Rona
3
Cornwall, uk
HYMER B585
10 years
Hi Steveib, did you ever find one as I've got the same issue! Ps the eBay link in the thread doesn't work ☹ thanks
Sep 17, 2017
5,461
10,193
Birmingham, UK
A-Class
The clips on my filler flap failed, so it was flapping in the wind. I found a replacement, same maker but the new model uses magnets. Issue was that the filler neck slots into the flap base. So I had to disassemble panels inside and free the pipe down to the tank. Took a couple of hours.
Magnetic works well. But it does attract the ferrous stuff in road grim, so there's permanent dirty round marks on the flap from where the magnets are embedded inside.
