Awning what make (1 Viewer)
May 29, 2014
2,054
1,667
southampton
A frame
since 1985
I anm trying to establish what make my awning is as it does not have a manufacturers label and not handbook or mention of the make in he Autotrail handbook Apache 634 2009
I need to resolve a problem whilst winding in or out the gearbox appears to jump a cog/tooth.
Advice appreciated, Guess it needs a new gearbox
May 31, 2015
11,688
44,554
Ducato PVC
Getting Better
Most likely fiamma or Thule.... my guess is fiamma.... but a picture would help..
mike mcglynn
Jan 6, 2008
2,700
32,552
St. Helens MERSEYSIDE
Autosleeper Warwick XL
A long time now
You May find a makers label on the inside of the case where the legs usually are hinged .
Dec 20, 2018
709
877
It's definitely an Omnistor, probably before the Thule takeover. I think it may be a 5002.
Hillview Awnings in Dorset are the people to speak to. Very helpful.
Reactions: f6c
11,956
16,571
Quick ID whether Fiamma or Thule/Omnistor: Thule/Omnistor legs use over-centre clamps whereas Fiamma uses screw Knobs.
pelican
May 29, 2014
2,054
1,667
southampton
A frame
since 1985
Thank you everyone who responded.
I spoke to a helpful and knowledgeable lady at Hillview Awnings new gearbox £68 inc delivery excellent service.
As the awning is recessed into the sidewall it needed releasing from the wall to enable replacement of end cap and gearbox,qwhole job about an hour probably half that if had to do again!
The problem with the gearbox was that 3 consecutive teeth on the drive gears had bent over and were jumping over each other,I can only assume that I had caused this by trying to wind into far trying to get the rear end cover lock to engage.
Perhaps if the gears were made of steel rather the aluminium casting the would be more durable.
Lesson learnt
Quackers
1,362
4,117
South Glos
Had exactly the same issue with our Auto Trail, took it to Hillvew Awnings and they sorted it. This seems to be a common issue, well done for repairing it yourself.
