Auxillary water tank DIY (1 Viewer)
Ridgeway
3,670
6,203
Lausanne
NiBi Arto 85E
The fresh water tank on our Laika is small for the number of people that use the van. We travel with 2 adults, 4 children and 2.5 dogs so we do need a reasonable capacity and we only have a 2/3 day autonomy range based on the vans standard 80ltr tank which we would like to extend. There was a factory option for this and the aux tank does come up on the display. I was thinking of a complete DIY rather than going down the expensive manufacturers parts, cant imagine how much theyd be, but just very expensive.
So I can source a suitable tank, Ive worked out how to secure into the space alloted for this extra tank but whats the usual method of filling an aux tank and do you normally feed the main from the aux
Ridgeway
Ridgeway
3,670
6,203
Lausanne
NiBi Arto 85E
and before anyone mentions payload, i accept that I would be 100kgs more than I am today
Jul 29, 2013
9,074
18,614
Salisbury
Hymer B678DL A class
I would think you could link the two together so that the same pump serves both and the fill point would fill both.
Ridgeway
Ridgeway
3,670
6,203
Lausanne
NiBi Arto 85E
so basically gravity fed, need to check if theres enough height for that, suspect not.
11,957
16,572
If the base of each tank is at the same level a pipe linking the bottom of one tank to the other is all you need - no pump or fill connection to tank 2. If the tops of the tanks aren't at the same level the breather from the lower tank must rise as high as the top of the highest tank.
Ridgeway
Ridgeway
3,670
6,203
Lausanne
NiBi Arto 85E
that sounds simple enough to achieve, may have to jack up the aux tank and play about with the heights a bit but this solution should do it, thanks
Bart
3,188
1,398
Northern Ireland
Boxer L4H2 van build
Since 2016
Currently thinking on doing the same in our bessacarr over the winter as 90ltrs goes wayyy to fast. That fast I near swear it's leaking ... But the only time I ever see water below it is when refilling the tank.
43,362
49,656
Sorry but Incorrect.....
The water entering the second tank needs to displace the air already in the second tank so a link both top and bottom required.
Bottom to allow water in, top to allow air out....and visa versa when emptying
11,957
16,572
Yep - I said that.:p
Jim
Ringleader
Jul 19, 2007
36,485
131,172
Sutton on Sea, UK
Adria Panel Van.
Since 1988
I had a motorhome with two tanks, one was slightly lower than the other. Connected in two places by a fat 1.5 inch hose. it was a year or two before I realised we had two tanks, in fact we only found out when one of those fat hoses came off while while driving too fast and bouncing around the racetrack at Stratford. :LOL:
Ridgeway
Ridgeway
3,670
6,203
Lausanne
NiBi Arto 85E
@Ridgeway did you ever add another fresh water tank ??
Job scheduled for this Spring, so no not yet.
Haven't decided whether to buy or build the tank yet, if bought it will be standard baffle tank but awkward to fit and a compromise on size, if built i can avoid those points but the job gets bigger...
11,957
16,572
I assume you know of CAK tanks when sourcing what you need - worth a look.
Sep 6, 2011
82
114
Carmarthenshire
WildAx Con3 XL PVC
Started 1989
A bit late to this thread but anyway: removed 88 litr inside locker tank, sold on eBay. Replaced with underfloor 120 litr underfloor tank, made to order by CAK Tanks. Excellent service from them, send them a drawing size, location for inlet outlets etc. Job total success
Ridgeway
Ridgeway
3,670
6,203
Lausanne
NiBi Arto 85E
Yes seen CAK tanks but it would be over €100 for delivery plus import duties etc. Going to see what I can find locally at a reasonable price. The official Laika unit is €350 ish...
Bart
3,188
1,398
Northern Ireland
Since 2016
how much did the 120ltr custom made tank cost you if you don't mind me asking
