Autotrail ceiling distortion (2 Viewers)
chris pilling
4
Abersoch
Fiat autotrail
3years
Hi everyone I'm new on here but been motorhoming for 3 years and we love it,we have a 2000 fiat autotrail in lovely condition,I've noticed the ceiling panel in the middle of the van a looks distorted and can sometimes look a little worse than other times(not sure if that's just my imagination though!!)it's a solid plastic panel and it's almost like it looks a little heat warped,is this possible?ive never seen any leaks at all inside the van and it all seems very dry everywhere.
C
chris pilling
4
Abersoch
Fiat autotrail
3years
It's hard to see in a pic but if you zoom in you might see what I mean
Jim
Ringleader
Jul 19, 2007
36,447
131,037
Sutton on Sea, UK
Adria Panel Van.
Since 1988
Hi Chris, welcome to the fun. Normally with distorted panels you would think, water ingress, but if its dry then you've little to worry about. Maybe there was some in the past and it was damaged then. Hopefully though its just a cosmetic thing and that's easy to cure. You just use all your will power and stop looking at it :)
C
chris pilling
4
Abersoch
Fiat autotrail
3years
Haha yeh that's what I've been trying to do recently!!I just woke up this morning and saw it on a different angle from the overhead cab bed!Is the only way to test for damp with a damp reader or are these panels easily removable from the inside?
Anthea M
Oct 18, 2015
9,501
165,143
Sheffield
Hobby
Hello and welcome !
It may be water ingress a damp metre will show that , is a habitation check due? I hope you get it sorted.
Sep 16, 2010
3,010
2,858
Bungay Suffolk
Autotrail TrackerEKS
Hi Chris.
Our Autotrail also had a little bit of the ceiling panel drooping slightly.
It is just a matter of the adhesive that holds the panel to the inside of the van, becoming unstuck...
A hypodermic syringe full of suitable glue will penetrate the panel and re-affix it.
Mitch.
19,376
30,366
I think you will find that the ceiling is a hardboard type material rather than being plastic and yes it may well stick back up. If it was damp you would very soon see staining on the board.
32,673
66,645
I do hope it's not a damp issue starting - if you can I'd suggest you go up onto the roof and check round all areas where there are apertures through the roof, ie roof vents, aerial etc just to make sure they are all in good condition and none of the sealant has cracked/shrunk or is missing/unstuck. Once you have confirmed that damp ingress isn't an issue then look at re-attaching it as described above by others.
C
chris pilling
4
Abersoch
Fiat autotrail
3years
Thankyou all very much for your replies,I'm pretty hopefull/confident it's an adhesive issue as it's also done the same above the cab bed at the front of the van and there's nothing at all above that part of the van where water could get in,was yours the same year Jenny/Mitch?like Martin has said it's quite a hard plastic so not sure how easy it would be to penetrate?this is a pic of the van....
