Autocruise starspirit door problems (1 Viewer)
reenag06
70
14
cheshire
I'm a newbie
I have a 2003 A/S starspirit and have just encountered a problem with the door lock to the habitation area, I can't get it to close. Is it easy to take apart and fix or how easy is it to get it replaced. Can't go anywhere until it sorted. Please help!!
Maureen
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
It is usually a spring that fails. Some have managed to replicate one but it isn't easy.
Olearys keep the whole assembly but they are not cheap. Also there are two types that look alike so need to establish which it is.
Is it this style?
http://www.olearymotorhomes.co.uk/motorhome-door-lock-fap-inner-1-1256-p.asp
reenag06
reenag06
70
14
cheshire
I'm a newbie
Yes it is that style. Is it easy to repair myself...
Thanks for replying
Maureen
Techno
Jul 28, 2010
15,475
20,756
May 2010
That depends on your skill level. Springs are not available, you would have to dismantle it find the broken part and replicate it. Perhaps a locksmith would be a better bet.
Techno
Jul 28, 2010
15,475
20,756
May 2010
Have you tried locking it from the inside? i.e. not using the key.
reenag06
reenag06
70
14
cheshire
I'm a newbie
Have had a fiddle with it and if I move the mechanism by hand can do it so will keep doing that for now and see how it goes - thanks for your help
Maureen
reenag06
reenag06
70
14
cheshire
I'm a newbie
In the end have had to get new lock, thanks Andy for sending inf.
reenag06
reenag06
70
14
cheshire
I'm a newbie
New lock just arrived but can't get old one off, I have undone the two screws at the side of the lock but where it shows four holes on the front - mine has the four marks but they are covered over with the full plastic cover - help please!!!
Techno
Jul 28, 2010
15,475
20,756
May 2010
You pry the plastic caps out with a pin
reenag06
reenag06
70
14
cheshire
I'm a newbie
Thanks will have a go, just looked like it was all one.....
reenag06
reenag06
70
14
cheshire
I'm a newbie
Done that, tried putting new lock on but the latch won't go down so not sure what I'm doing wrong now or if the problem was something else.!,
reenag06
reenag06
70
14
cheshire
I'm a newbie
You been great help but don't know what to do now - thanks for all you have done.
Techno
Jul 28, 2010
15,475
20,756
May 2010
Without the internal side fitted does the external part work, does the key turn the lock shaft
reenag06
reenag06
70
14
cheshire
I'm a newbie
Yes key turns and external part seems ok
reenag06
reenag06
70
14
cheshire
I'm a newbie
Will keep trying but will get back to you if can't fix it as would be great if you could have a look.
reenag06
reenag06
70
14
cheshire
I'm a newbie
Have tried but no luck have given up for tonight.... Will start afresh tomorrow!
reenag06
reenag06
70
14
cheshire
I'm a newbie
We'll have been trying again unsuccessfully and am very frustrated as just don't understand it unless new lock isn't working as well. I thought that new lock should work before putting it on door, I.e. When I move lever the latch should move but it doesn't so put it on door and still doesn't work.
reenag06
reenag06
70
14
cheshire
I'm a newbie
Hi guys, thanks so much for all your help with door problem. Apart from spring broken and not being able to get new lock working, I persevered and it was the clasp plate on the other side which was ever so slightly bent so have managed to straighten it and works perfect!
Can't tell you all how much I appreciate your help. This site is so friendly and helpful.
Maureen
