I'm trying to finalise the last few big items to fit into my Camper re-build.
I've had a compressor fridge for the last 4 years, which has worked faultlessly, but because I'm always worried about power consumption (need power to work), I've often switched the fridge off.
Although the re-build will have far more usable power, I think I'd prefer to keep electrical use to a minimum. So I'm thinking a 3-way fridge might be a better choice?
I've read often that for gas use the van needs to be level. How level?
Are we talking within 1/2 degree level or within say 5 degrees?
I've also read about issues in warmer climates. My van is very insulated, so tends to stay quite cool in the Summer. If I leave the insulation behind the fridge, apart from where the vents fit, and fit a temperature controlled fan to the vent, would this probably combat the problem? Anything else that may help?
Finally, I'm not sure which make to go for. The common brands seem to be Dometic and Thetford.
I'd be looking for something around 100ltrs. Any recommendations?
Is there anything else I need to think about with a 3-way fridge?
Thanks,
David
Thanks,
David
