Another Gadget Or Two For Filling Your Water tank! (1 Viewer)
Wombles
10,808
11,132
SW England
A few years now
Know a lot on here, like us, are big fans of the HEOSwater filler cap & other similar filling devices but spotted this adapter on a couple of Facebook groups today & don't think it has been posted here so hope they (thank you Adam (y)) don't mind us sharing:
Wombles
Wombles
10,808
11,132
SW England
A few years now
Gellyneck
9,235
18,210
More than toes wet now!
It's a Gardena Angled Tap Connector & cheapest we found including delivery was here http://rover.ebay.com/rover/1/710-5...0001&campid=5338547443&icep_item=123851227755 at £4.75.
Mr Wombles wants one to try so less kinks in our hose!
As well as the original poster in the UK it looks like from the Facebook chat that motorhomers have been using these in France for years.
DBK John, we're you not looking for something like this? (or have I got it all wrong again!)
Wombles
Wombles
10,808
11,132
SW England
A few years now
Does the water level gauge not work on your van Wombles ?
Yes - but it's not that accurate & Mr Wombles finds it easier with the meter as he can get other jobs done while it's filling without having to pop in & out of the van to check.
18,025
48,095
Thanks for that, I made up my own thingie to avoid the problem of the hose cutting off the supply. This happens with low water pressure and especially with a lay flat hose. :)
Nov 17, 2012
1,930
2,614
WEST SUSSEX
HYMER B SL 674
SINCE 2005
I use a 10 litre watering can. 1 load is 10 litres, 2 loads are 20 litres can you see the pattern emerging here
Exactly what we do so when setting off just pop 2 1/2 loads in and as appropriate thereafter. The plastic jerry shape is easier to store than watering can which we often see on campsites and usually only hold 5 litres
Kannon Fodda
2,579
7,984
Seek and Ye May Find
Autotrail V-line 540
I Make Schoolboy Errors!
I wonder if the Wombles have any room left on their MH for themselves they seem to have access to so many toys. :D
SuperMike
2,477
7,593
St Albans
Winnebago Sightseer
Now let me see.
Water tank 340 litres, using one 10 litre watering can equals 34 loads and half a days work. :rofl:
32,656
66,561
So we just fill ours till the water comes out the hole. Then you know it is full.
I think the idea is only to put in a certain amount rather than fill it totally as not everyone likes to travel with full tanks.
32,656
66,561
This is my version as our camper doesn't like the Heosafe water filler adaptors, it's a coat hanger 'hook' slotted through the pipe, then cable tied and taped round, this hooks onto the ledge of the filler point (you have to ensure you get the distance correct when making it so the length is right so it's a tight fit). In use it works perfectly, no need to hold onto to it and if it fills without us noticing the excess can easily come out. I put the info on my website:
If filling up with water on your own trying to hold the hose in the fill point and turn on the tap can be difficult and you easily end up with an unintended shower, so I made a 'hook' which sits in the small indented channel in the filler which once on doesn't budge until I want it to. I removed the metal hanging hook off a metal/plastic clothes hanger for this purpose. In order to get the placement right I put the hose in the filler point, hooked the metal hook into the channel and then marked on the hose where the end sat, I then put a small hole in it using a screwdriver and pushed the 'straighter' end of the hose in, fastened it securely with a cable tie then taped round it - it sits securely in the filler point so I don't have to keep holding it!
Feb 22, 2011
9,791
20,158
Newcastle under Lyme
Hymer B544 A Class
I time the fill, empty to full on house water pressure is six minutes, if I only want half a tank then three minutes - simple, no need for gadgets.
Nov 17, 2012
1,930
2,614
WEST SUSSEX
HYMER B SL 674
SINCE 2005
...and mightbe a challenge with the weight criteria for the vehicle, 1L = 1K so not sure I would want an additional 160k whilst on the road (or maybe more cannot remember!). Some, maybe most, have a 25L overflow on the tanks to prevent this issue
Aug 26, 2008
4,762
24,959
B&NES
since 2007
Now let me see.
On the plus side, carrying and lifting a 10 litre watering can is good exercise.
5 loads = 50 litres, the amount recommended by my Rapido handbook for travel. Job done!
Wombles
Wombles
10,808
11,132
SW England
A few years now
357
822
Swindon
since 2007
Talking of which. I was on a site a few weeks back which had a serviced pitch. So I attached the hose when we arrived and added 70lts, thinking this would do us until we left and I could always add a little before I left if needed. A day before we left the little darling at the back of our pitch decided to bugger about with the handles to the water taps. First thing we knew was the tank overflowing via the filler!
Now I had 230lts on board, as our van has an extra tank. Problem being the site didnt have a MH point to drain it off and nothing on the pitch to drain into.
Luckily they let me stop outside the exit on a slight slope so I could drain off into a road drain.
Wombles
Wombles
10,808
11,132
SW England
A few years now
The light blue ones are £92.99. Nearly ordered one at this price by mistake
That's what eBay business sellers sometimes do when stock is low (as mentioned in this sellers item description) to hold the listing open so they don't have to pay the fees for a new listing - if wrong one was ordered in error then it is possible to cancel. Anyone ordering this does need to click on the drop down for the dark blue one at £12.99 so as Tribbtravs mentioned make sure that you look out for that. We have ordered a dark blue one from this seller previously & it was all fine.
32,656
66,561
Am I right in saying that's the old version, not the new one which has been redesigned and is more money?
Wombles
Wombles
10,808
11,132
SW England
A few years now
It's the 2 in 1 version as in the photos above - there is a 3 in 1 version now but not necessarily any better depending on your application & it does cost more.
Kannon Fodda
2,579
7,984
Just used the original version watering can thingy bought into anticipation of getting a new toy today. Worked well apart from that final 1/4 litre dribble. Must find about 5” of hose to lengthen the spout and I’ll never need these weird hose filler gadgets with a pitiful 50 litre capacity.
