And.. it sort of continues !! (1 Viewer)
23,836
72,479
Just checked on something and had cause to turn the fan on in the cab..
Bloody control resistor has blown.. All I have is flat out of nowt, so I know full well what it is.
Ordered a replacement ( £12.95 ) but now have the wonderful job of trying to figure out how to take most of the lower dash apart to get at it !
andy63
4,672
15,017
south shields
since 1990
just do it lol... I took the dash out of my van for no other reason than to trace some wires... it came with an aux fuse box fitted and ford were no help at all ..in the end I just had to bite the bullet as they say...
enjoy it ...im sure you will sort it ..
ta andy
Aug 18, 2014
23,782
133,652
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
Can you do mine as well please ?
ta andy
You'd be finished quicker if so much tea wasn't evident .:D
Nov 6, 2013
1,416
3,170
S. Ayrshire
The usual
Since the beginning
ta andy
That's one of those "quick jobs" .... that escalated :winky:
ebo
Nov 9, 2009
98
105
A class Carado i449
I'm looking forward to this if the step is anything to go by, good luck Jaws
rolandrat
436
258
Lancashire
Hi Top
That's one way of putting people off motorhomes that's for sure. Changing fuses ok but major dash strip downs no way, unless you know what your doing.
rolandrat
436
258
Lancashire
Hi Top
ta andy
What are you looking for?
andy63
4,672
15,017
south shields
since 1990
I didn't lol ..a steep learning curve :LOL:
don't want to be hijacking jaws thread but posted picture as a bit of a joke with jaws..
a brief reply to you ....my van is a panel van conversion.. the van came with an aux fuse box set up which I believe is not that common but I decided to utilise that feature for some of my circuits ..was trying to keep any additional wiring as separate from vehicle wiring as possible and it became obvious I was going to have to find the source of some of the wiring.. I thought the easiest way was to remove the dash and trace the wires....all that was a few years ago... and that's the reason :)
I wonder will jaws post a picture of his dash strip down to replace the blower resistor...??????
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
Heater blower resistor pack is a doddle on Ducatos of almost all ages, on the X250 you can get at it from just below the passengers glovebox. Could be worth getting a new plug and wiring (available on ebay) as they're known for burning the contacts.
D.
23,836
72,479
D.
Thanks for the Dave.. save me digging around looking.. I knew it was somewhere in the air stream but not where !
Yes.. its a typical poorly thought out system..
If there is ANY sign of over heating of the connector block I will remove the plug and socket completely and solder the wires together as I do on some wayward motorcycle charging systems.
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
New plugs are available with wire tails fitted John, at least one of the Vauxhall range uses the same plug and wiring.
D.
23,836
72,479
Yesssss.. But sooner or later they will end up the same.. They are using a spade type connection ( which when you analyse it has small contact areas ) for a high amperage application.. cutting the things right off and soldering is a far better and more permanent solution ( though I appreciate not for every one of course ! :) )
I will remove a bit of the plastic and solder tails to the terminals of the resistor, cut the wires off the plug and hey presto ! Job jobbe
23,836
72,479
I have ABOUT 10 mains irons, three gas ones, and two 12v ones ( that are bloody useless even though they are Antex )
The gas ones are really excellent though (y)
cruiser
4,219
4,951
northampton
coach built elddis 400
since 1978
yes my son swears by his gas one. unless it is very windy
23,836
72,479
D.
As a matter of interest, before I started the job I did have a look at those Dave.. £25 a go !!!
Pass ! ;)
Took the old resistor out and somewhat frazzled.
Looked in the end of the plug and yes, could see where it had at some time got hot.. Not gone yet but a definite potential issue in the future.
Cut away a bit of the plastic shroud on the new one, and soldered a couple of inches of wire to each tag. ( I used some solid core stuff from an odd bit of 2.5 twin and earth )
Cut the wires off the socket end and soldered to the new wires.. Refitted and jobs a good un (y)(y)
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
ta andy
I though the screen had to go too to get the top screws unless they are using clips now.
andy63
4,672
15,017
south shields
since 1990
If I'm picking you up right, no screws to remove at the front. A few rivits to drill out at rhe front which I replaced with riv nuts to make the job easier if it ever has to come out again.
Tpa andy
Apr 13, 2012
5,544
18,775
Mobilvetta Euroyacht
1996, then break 'til 2011
ta andy
Looks like something out of 'Terminator
Brave man(y)
23,836
72,479
OH SOD IT !!!!!!!!!!!!
mate has just popped round with a wee box in his hand..
here ya go mate.. That heater control you wanted ..
But I ordered one off fleabay and it is fitted.. You never got back to me ( works for a Pug main dealer )
Ahh errrrrr
Well seeing as he is a good source of genuine parts I did not want to upset him.. so paid him for it..
If anyone wants a genuine Fiat / Pug resistor pack for £12.00 gimme a shout !
