Ammeter on AC EHU Side (1 Viewer)
Feb 20, 2017
838
2,431
Kent
Bailey 75-2
Tugger now Motorhome
Has anyone fitted one to monitor EHU current usage. I searched here but found nothing?
Apr 27, 2016
6,560
7,425
Manchester
A class Hymer
Since the 80s
Yes, I've fitted one of these, as suggested by @pappajohn
https://www.ebay.co.uk/itm/Owl-Micr...m=112355613242&_trksid=p2047675.c100012.m1985
It's in two parts. A plastic-covered sensor clips round the live wire (round the plastic insulation so it's quite safe). The sensor is attached to a battery-powered transmitter, which is stuck on the wall next to the sensor. It must clip round either the live or neutral wire. If you clip it round both it will read zero.
The display picks up the signal from the transmitter, and displays the amps. If you tell it the voltage (eg 240 volts) it can show the power being used, and the power consumption over time. If you tell it the cost per unit it will even show the cost of the power used. The batteries seem to last years rather than months
Steve N Tracy
1,189
4,647
Southampton
4 Years
Back in my caravan days with the Truma Ultraheat set up, to avoid the missus putting everything on and popping the bollard I fitted a unit similar to this.
