Amber warning light! (1 Viewer)
Feb 16, 2010
295
282
Newport, Gwent
2002(previously 25 years caravaning
whilst travelling on the AP68 to Zaragoza, an amber warning light which shows Injection System Failure appeared on my Fiat 3L Multijet. Checking the manual, it say's can still be driven but could cause high emissions at the exhaust and possible lack of performance. Carried on for another 300 miles and found no difference in performance. Any ideas?
Two on Tour
10,327
50,956
Elddis Autoquest 175
Since 2010
Try disconnect the negative battery lead and leave the lead off for 10 minutes before re-connecting. If it's nothing serious or permanent then that should clear the light.
You my well have to reset you radio with your code though.
Dec 12, 2010
5,411
21,562
Cumbria
since 2011
Doesn't that sometimes signal that problem with the "stretched" injector wiring harness ?
Derbyshire wanderer
1,288
2,390
Derbyshire
C class
15 years
When mine came on it was due to a failed dpf pressure sensor. All ran ok but would not do a burn off so was effectively clogging up the filter till it was replaced
Jan 22, 2012
1,459
2,229
Wigan
Knaus Sun TI 2012
We had the same problem going through Austria last year. It went off for a while when I filled up with premium diesel, but then came back on again. Got home ok with no problems, went to my garage and they reset it said it was nothing and charged me 40 quid. A few miles later it came back on. Since then we've had several long trips around uk. Will take it back to garage when my service is due and hope they find a way of getting the light to go off. Vehicle is a Fiat and only done 24k miles.
May 9, 2011
145
223
Cheshire / Vale De Parra
Rapido V55
Since 2011
Happened to me in France, last September driving to the Algarve, after two fuel stops went off, travelling back home came on again. Fiat garage in UK diagnosed lambda sensor faulty, replaced under warranty. 3ltr Fiat with 23000 miles
Sep 28, 2015
2,017
2,613
Kingston upon Hull, East Yorkshire.
Hymer B544
2001 Caravans 2011 Motorhomes
Happened to us on our 2.3 early last year whilst in France. Fiat Professional garage in Avranche reset it and said there was no problem, it came back on straight away so they did further investigation and replaced the throttle body. No further problems but all the time the engine had run perfectly, although after it was replaced I started thinking it was smoother and more powerful. I could have been trying to justify the 360€ it cost.
Two on Tour
10,327
50,956
Since 2010
I always carry one these in the glove box of each of our vehicles. It's a bluetooth fault code reader that you plug into your OBD port. I have the app called Torque which communicates with the code reader to tell you what the fault is and the "P" code that relates to it. The Torque app does a load more functions giving you a real time readout of various sensor data.
