- Feb 22, 2011
- 9,796
- 20,171
- Hymer B544 A Class
- Since 2015
My cab air con sprang a leak last year and I had it repaired by a mobile guy who replaced the evaporator.
All seemed ok but but it lost the freon after a few days.
He came back and found the high pressure tube had rubbed on the radiator and worn through.
The recommended repair was to cut the tube and re-join with a special compression fitting.
This was done and since then the joint has failed after a few days about 3 or 4 times now, most recently it was gassed two weeks ago and yesterday I took the van for a run, tested the AC and there's no cooling again.
I'm losing faith in this repair now and wondered if a replacement hose was a better option ?
The hose is no longer available, it's a 2003 2.8 jtd x244 ducato, but I wondered if a generic flexible hose was an option, and if anyone might know where to source one from ?
The AC guy should know of course but he hasn't suggested this so far
The original hose is part aluminium part rubber.
TIA
TIA
