Air bag warning light help please (2 Viewers)
SandJ
1,799
818
North Yorks
Too long lol
Fiat x250 2011
Passenger airbag warning light staying on any ideas please?
TIA
sdc77
3,244
4,550
Weardale, Co Durham
I'm sure there's a previous thread on a fiat airbag warning light..
I do know though that these are actually restraint system warning lights and can be activated by faulty connections to the front seat belt connectors.. Or occupancy sensors.
SandJ
SandJ
1,799
818
North Yorks
Too long lol
Thanks I have done a search but nothing found hence the request:thumb:
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
Look for wiring connections or damaged wires under the seat.
make sure the ignition is off or it can activate the airbag.
has it got a switch to dissable the passenger airbag? some do, some don't.
SandJ
SandJ
1,799
818
North Yorks
Too long lol
Can't find any loose wires and according to handbook there does not seem to be a way of turning it off.
Looks like I need to book it into Fiat :cry:
Daedalus
86
160
North Cumbria
Since 2000
Fiat x250 2011
TIA
Don't know whether it's the same fault, but this happened on my car - turned out to be the air bag firing squib had gone duff - apparently it's very easy for a competent garage, with the relevant diagnostic equipment, to check and inform you exactly what is wrong.
Shouldn't cost a fortune either.
HTH
Daedalus
SandJ
SandJ
1,799
818
North Yorks
Too long lol
Sorted
Couldn't find it in manual but may have missed it
As to why it happened?
Incase someone else needs fix then
Mode on right of dash press mode then up button till Bag P then mode
up till On is displayed then Mode
Conf
Up till on is displayed then Mode
It should display
Bag P
On
Sorted:thumb:
12,141
18,009
derbys
AUTOSLEEPER SYMBOL
Sorted
Mode on right of dash press mode then up button till Bag P then mode up till On is displayed then Mode
Conf
Is should display
Bag P
On
Sorted:thumb:
God that sounds to high tech for me. BUSBY:roflmto:
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
Do you actually have a passenger air bag? If so then what has happened by some means or other is it has been switched off ( a setting to allow a child seat to be used in safety on the front passenger seat). When its switched off there is a warning light to alert the driver to this fact. The de-activation of the passenger seat airbag has for a long time been done via a key switch, often located in the glove box.
D.
SandJ
SandJ
1,799
818
North Yorks
Too long lol
D.
Dave as to why it came on then that is a mystery :Eeek:
It does have a passenger airbag and yes it was that warning light but if you see my earlier post it is turned off/on by the mode button see. Photo attached
:thumb:
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
:thumb:
I read your post and understood it, I was simply trying to clarify for others that on many vehicles disarming the passenger airbag in order to use a child seat was done via a key switch often located in the glove box, I wasn't trying to say yours should be like this at all. I should have been clearer in my explanation:winky:.
D.
bobandjanie
8,165
15,812
Javea, Spain
Pilote V600g
Glad its sorted Steve, something else I have to remember, :winky: mind the mode buttons when spring cleaning. :roflmto: Bob.
