air bag light (1 Viewer)
Jul 8, 2008
1,137
1,467
Weymouth, Dorset, UK
c build
6 yr
hello my air bag light came on when driving now
i have look under the seat for wires But can not see any
so were do i look please
thx s dave
53,476
150,187
Under the seat it would only be the wires for the seat belt warning, the air bag on the drivers side is in the top of the steering column and under the dash on the passenger side. Not advisable to play around with air bags unless you fully understand them and know what you are doing otherwise it can result in serious injury.
May 8, 2011
3,867
48,544
God's county. Helmsley, North Yorkshire.
IH Tio 630 RL
Since April 1846 but have always camped.
Mine came on in August this year in Port Grimaud. Took it to the nearby Renault dealer. They plugged it in to the computer, said it was a loose wire and charged me €170! Lol!
23,836
72,511
Looks like another code reader / resetter might soon be on order :xwink:
Nov 23, 2011
479
405
durham
Lowline
since 2006
Mine came on last year while travelling through France. Checked over what I could but couldn't find anything wrong. Got it checked out when we returned to UK and it was the air bag control box. Luckily it was replaced under warranty. Dealer did say that with the air bag light on the air bags would not have activated in a collision so be careful.
23,836
72,511
Umm.. so you are NOT careful if the light is out !!!!!!!!! ????????? LOL !!:xrofl:
Personally I recon all air bags should be removed and replaced with a steel spike that shoots out.. Now THAT would make people drive with care :xThumb:
43,332
49,505
Dont fiddle with airbags or belt pre-tensioners unless you are trained.
Bloody dangerous things in the wrong hands.
Airbag warning light means it will not deploy....not dangerous in itself but no protection in an accident.
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
The wiring under the seat would be for the seat belt pretenioners which are part of the SRS (Supplementary Restraint System, or airbag system to you and me). It may help if you could tell us what vehicle we're talking about. Seatbelt pre tensioner wiring is probably the most common issue but it could be the "clock spring" mech in the steering wheel.
D.
Aug 18, 2014
23,797
133,854
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
Have you ever seen the you tube clip in the garage where they place a seat on an air bag & one of th blokes sits on it when they set it off ? shoots him right across the room.
2bob
Jul 8, 2008
1,137
1,467
c build
6 yr
D.
sorry through i did
its a 2.8jtd 05 plate no wires under seat
Tony drake
68
45
Poole
Coachbuild
Since 2008
Hi Bob
I have a decent code reader that reads airbags, abs etc and live in Poole Dorset. Happy for you to pop it over if want too and I'll plug in for you?
jonandshell
5,476
8,299
Not got one!
Steering wheel ribbon a likely culprit!
Tony drake
68
45
Poole
Coachbuild
Since 2008
HI TONY will let u know as a friend might help 1 min away
thx s
No problem Bob , I travel all over the country so if you get stuck I might be passing you. Happy to help if you need me to.
Aug 18, 2014
23,797
133,854
Lorca,Murcia,Spain
Transit PVC
hi tony think i need a new ecu or a repair one
enssenjay can not connect to it say ecu us
If it is the same as other vehicles then a new one will cost a fortune + programming & they'll want it paid in advance in case it doesn't cure the fault as a new one , once programmed to your car, cannot be returned & is useless.
The second hand route means that you normally need the ecu, Any other electronic units as well, the ignition lock + keys , & the immobiliser unit. Everything would have to be changed.
Hopefully yours is repairable.
2bob
Jul 8, 2008
1,137
1,467
c build
6 yr
now got to find a firm thats repairs them
this ecu is for airbag and not eng
Oct 14, 2007
3,995
6,255
Rochester
Auto-Trail Mohawk
16 fun filled years
Mine came on a couple of months ago, took it in and there was a fault on the airbag ECU, got it replaced under warranty.
Tony drake
68
45
Poole
Coachbuild
Since 2008
Happy to try and connect with my diagnostic equipment and give it a try if you want me too Bob. Sorry for the late reply, been working away.
18,033
48,138
Had my airbag ecu replaced under warranty last week. 2013 Ducato 250, no idea why it should have failed. I had checked under the seat for loose wires but found nothing obvious so let the garage identify and fix it.
Worth repeating here if you have rotating front seats don't turn them round in the same direction as this will wind up and break the wires. Rotate the seats round to the position you want then return them by turning back in the opposite direction, so if it was clockwise to turn then anticlockwise to put back. :)
Tony drake
68
45
Poole
Coachbuild
Since 2008
thx Tony i think it needs a new or second hand one enssnjay are fita specialist could not connect
Happy to try if you want to Bob. I can clone engine ecus but I'm not sure on airbag ones. I will speak to the guys in the office and let you know if it's possible.
