Boringfrog
- Jul 13, 2008
- 3,787
- 4,701
- Low profile
- Since 2007
It's fully automatic so cannot choose.If you are on EHU, use electric. If travelling, i.e. engine on, make sure “battery” is switched in. If neither, e.g. at a supermarket, turn on the gas supply and switch fridge to “gas”, you should hear the gas click on.
Is there really no option for manual override? What make is it?It's fully automatic so cannot choose.
It's a RM7505.Boringfrog
Really need make and model for advice. Often a label inside the fridge, perhaps at bottom on back wall behind salad drawer.
RM7505 DometicIs there really no option for manual override? What make is it?
Yeah, tried that a few times, if gas is off red light starts flashing, I can hear a clunk too, relay maybes?And presumably switching off and back on doesn’t mend it?
No I haven't, I wondered if you needed the gas on?We had the same model in our old Hymer, and folks wouldn't believe me when I'd explain that it was fully automatic, with no option to choose the power supply.
One of the facilities of these AES fridge/freezers, is that when on EHU, the gas supply should be on, as when the voltage drops below 220v (as often happens at peak times on some Spanish sites, the F/F will click over to gas, assisting the electrical element to maintain the temperature. During the day, you may not experience the changeover, but mornings and evenings, you'll often hear the relay kick in, the igniter sparking a couple of times, then the ignition of the flame. It can be minutes or much longer before you hear the changeover to mains power again. Our Electrolux RM7505 was so reliable, and was twenty years old when it went to it's new home.
Boringfrog, have you managed to suss it out yet?
Cheers,
Jock.
Nope.Hi Boringfrog. Did you manage to get to the bottom of the fridge problem?
Your fridge is wired incorrectly. It should only be able to select 12v if the engine is running.AES is a pain on my fridge/freezer. Default sequence is 240v / 12v / gas so drained the leisure batteries overnight first day away a few months ago. Have to manually override to gas when not in EHU to avoid the same.
Nah - manual is clear on sequence but does warn not to use on 12v unless engine running, which is easy to understand with 20/20 hindsightYour fridge is wired incorrectly. It should only be able to select 12v if the engine is running.
But it should be wired to only us 12v in that sequence when it has a signal that the engine is running as Peter says.Nah - manual is clear on sequence but does warn not to use on 12v unless engine running, which is easy to understand with 20/20 hindsight
The 12v energy supply (as opposed to the supply to run the electronics) to your AES fridge is directly wired to your leisure batteries, and that is incorrect. It should be wired to your engine battery via a relay which only switches it on when the engine is running. The whole point of an AES fridge is that it uses 240v if you are on hook up, 12v if the engine is running or gas in all other circumstances.Nah - manual is clear on sequence but does warn not to use on 12v unless engine running, which is easy to understand with 20/20 hindsight
It means what I have said above. But clearly there is a problem with the wiring if it allows the 12v to continue when the engine is off.I'll need to do a bit of digging to see what that actually means.
Until you drive into a garage to fill up and somebody using a nearby pump spills some petrol, and your gas flame ignites the fumes. That is why the gas mode in an AES fridge does not switch on until 15 to 20 minutes after you have switched the engine off.I very rarely use EHU so no big deal keeping it on gas all the time tbh.
The fridge control board should have a wire to the D+ signal that tells it the alternator is running. The power to the fridge 12V heater element should run from the starter battery/alternator.But clearly there is a problem with the wiring if it allows the 12v to continue when the engine is off.
Yes, the gas supply needs to be on, as I explained earlier, as when the mains voltage is insufficient, the gas will automatically kick in. It can't do that if the supply is isolated, hence the rapid flashing of the gas indicator, telling you that there is no gas supply.No I haven't, I wondered if you needed the gas on?
