- Jul 13, 2020
- 733
- 2,571
- 'Inbetweeners'
- Newbie. Motor home experience began on 1/8/2020.
Hi all,
I think I must have read every article, post and bit of advice on this issue and still cannot remove the air lock. We have just bought our first MH, an Autocruise Gleneagle. The pump ran on a little and was a bit noisy so I decided to change it for a Shurflo. I did this on Tuesday. I have spent most of the rest of this week trying to obtain an even flow of water without the accompanying spluttering. I would say the issue is pretty bad and much much worse than anything experienced in the previous three weeks (lesson learnt!)
I have drained the water heater, first trying the nearest tap and then the one furthest from the pump. I have tried the cold first and then the hot first (or possibly the other way around). I haven't tried ' blasting ' water through the shower hose with a hose pipe.
I have driven down to fill up with diesel. I even tried warming the water (a little).
We are off away for the weekend now so hoping the drive (not too far but hopefully far enough) might shake things up a bit and help solve the problem.
So the point of my request for help.
I will obviously try again when pitched up and will update on the situation.
In the meantime if the experts in water/plumbing air locks, could find a minute to ponder what I haven't tried and suggest it, I would be very grateful.
Thanks in anticipation and as Tony used to say BFN (was it Tony?)
