Lucky
- Nov 9, 2019
- 532
- 1,057
- Sunlight Cliff 600XV
- Since 2016
According to a posting on the Dethleffs Owners Facebook page, Dethleffs has stated that a factory fitted towbar with chassis extensions on a Fiat low chassis INCREASES garage load capacity of a Pulse from 150 kg to 250kg.
I kind of understand because the floor might be better supported but I'd expect Dethleffsbut did not would caveat that comment by saying the towbar and chassis extensions will also detract from the overall payload, which itself is split across the front and rear axles. Moreover you should check your rear axle loading at a weighbridge before assuming you can safely put 250kg in your garage.
Am I being overly critical of the advice being given by Dethleffs or am I just plain wrong?
On the upside, I never knew you could increase your garage load so easily.
