thIOM
I connected the mains cable to the van today for the first time since I got it, as I noticed that the red light was flashing on the control panel to warn me that the leisure battery is low. After connecting the mains lead the control panel does not indicate that the power is connected and the lights and step will not operate. The red light continues to flash, but does go out if I start the engine. Presumably the alternator is sending current to the battery but I assume the 240v connection isn't. I have checked the safety cut out switch, which is in the on position, so this is not the issue. I have also checked the Electroblock (EBL99) and looked at the "batterie" switch but the manual does not make it clear what position that should be in. I presume it was in the right position as the step worked when I put it down, from the leisure battery and I am not aware that it has been touched since. Any ideas, please?
