2018 Ducato battery
GrahamCardiff
Cardiff
PVC Sunlight Cliff
Since 2018
Hi Folks
Am still trying to sort out my key fob (see earlier post)
Am trying to loosen the nut to the battery lead to see if disconnecting might sort it. It won’t budge. Is it fixed in place or something? Don’t want to put too much pressure on it.
Thanks.
Hi Folks
Thanks.
Try tapping it with something. Sometimes they get a bit stuck because the lead post is soft.
Negative is just a lever.
To take the Positive terminal off you have to undo the 2 self tappers in the red locating strip as well as the terminal nut.
Thanks , is this for a 2018 model?
Yep as Lenny said the neg is just a lever clamp and the poss has to have the 2 screws holding the red strip down then undo the clamp. Bolt.
Just disconnect the negative if you're resetting by removing all power. You're supposed to disconnect that first anyway so you don't short the positive to ground with your spanner 👍
If you have more than a lever operated earth connection, you may have a key switch operated battery isolator fitted to the earth terminal. (there will be a button you press located at the key/starter switch if you have this feature fitted)
Here you go Andy Techno making life easier for you. 😁 Bob.
