1996 fiat ducato 2.5 Tdi cat oil leak (2 Viewers)
wavehead
9
uk
coachbuilkt
I have a well used 150,000 miles Fiat ducato 2,5 Tdi cat 1996 with a small slow oil leak, it appears to come from behind and high up by a sheet metal plate between the engine block and clutch housing and drips out along it and mainly from the bottom making a mess underneath especially when driving,then basically stopping after engine is off. The problem has been going for a year/3000 miles gradually getting worse, any ideas gratefully received.:Sad:
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
Can't figure out where it is from your description but it could be the rear crank seal. They generally leak when the engine is running
Is your clutch ok? A leak on the rear seal can get thrown about and end up on the clutch plate
Allan
43,337
49,538
sounds like the gearbox end of the cam cover gasket if it's high up.
Can't remember off hand but I think the brake vacuum pump is driven off the end of the camshaft, if it is the the oil seal may be leaking.
Not a difficult job to replace the seal.
W
wavehead
9
uk
coachbuilkt
Allan
Clutch seems fine, your idea seems ok but major job to fix I would think?
W
wavehead
9
uk
coachbuilkt
Surely it means the gearbox clutch have to be removed just to start with if thats the case:cry:
43,337
49,538
No.
The gasket is as far up the engine as you can get...it seals the cam cover to the cylinder head.
The vacuum pump is on the end of the cam shaft which is at the top of the engine...well above the clutch and gearbox.
No offence, But it does appear your mechanical knowledge is limited so I suggest getting someone to have a look for you.
Oct 5, 2009
348
315
anglesey
Autotrail Delaware
Might be a good idea to check the engine breather system is clear, can become clogged up on an oldish engine the excess crankcase pressure could make old and possibly weak oil seals leak.
If its a turbo it will have a high pressure external oil feed to it that can cause problems internal oil leaks on the turbo are usually burnt of resulting in a smoky exhaust.
W
wavehead
9
uk
coachbuilkt
No.
Sorry about that got confused wth the other answer,thought you meant crankshaft. The leak is not that high and is more likely a crankshaft seal fault and the oil is being sprayedup the seal area as most comes out the bottom of the cltch housing to engine seal. Thanks anyway.
W
wavehead
9
uk
coachbuilkt
Okay nice idea, it is Turbo checked where the pipe goes back into the i/p from main air filter area. It seemed oily in the pipe but there was a steady fairly weak phut phut phut of oily air coming out would this be normal? I looked in the wire filter box and could see an oily steel wire mesh, is this normal. Cannot see how to remove the box after taking 2 nuts off.
Any further help gratefully received..............
