Hi, I have a 1995 Hymer B654. A couple of weeks ago the water started glugging, that is to say it was returning through the pump back into the tank, just as soon as the taps were turned off. I changed the pump (and I’ve tested it, it works perfectly, as indeed did the previous pump). It is very frustrating. The micro switches seem to work correctly. Is there a non return valve (that may have failed) hidden away in some dark and unknown location, or indeed not? Because if so, it is not self evident. I do also understand that this “older” system is pressurised.
Any help would be much appreciated. I have looked online and also here at Motorhomefun, on the relevant “water” section, but have found nothing that comes up with a satisfactory remedy.
Kind Regards
Dee
Kind Regards
Dee
