All,
Looking for some good advice for purchasing a good 12v battery and invertor.
Please note i am not going down the lithium battery route as I cant afford them.
TV and sat reciver OK but better to use 12v ones more efficient. For the hair dryer, you are going to need an 1800 to 2000 watt inverter and if you value your batteries at least 300 a/h of batteries, i.e. 3 x100a/h batteries.
Your TV may appear to be a 240v version, but may be supplied from a power supply. If it is take a look at the power supply output voltage.
I run an LG TV which has a 19v power supply. It was quite easy to replace the 240-19 volt power supply with a 12-19 volt version.
Geoff
