Your Best top tip! (1 Viewer)
mulaz
97
Durham
3 years
Mine would be the king size mattress topper that we bought at IKEA .we used it for a short time in the house then stored away until one day after a bad week of restless nights on cheap foam filled bedding, constantly falling into the gap between 2 separate single foam cushions. i started searching on Ebay for a foam memory mattress then thought ! we have a mattress topper in the loft already. i dragged it out at once .It fitted perfectly in our overhead bed and has made the biggest difference , no more sleepless nights just bliss
This topper is not the foam memory type but similar to a regular mattress but only 2" thick This to me is the best improvement to our van::bigsmile:
Apr 29, 2009
1,206
741
West Sussex
Burstner Nexxo T740
We now use two XL Sleeping bags zipped together instead of sheets/duvet. Bed is much easier to make up now after a few glasses of wine.:Smile:
tincan
14
16
Prevention better than cure
When emptying waste down the sink, filter everything through a sieve and only allow water down the drain. This leaves only liquid to be dumped and less chance of solids forming in clumps leaving smells. The sieve can be emptied in the bin.
Jim
Ringleader
Jul 19, 2007
36,462
131,089
Sutton on Sea, UK
Adria Panel Van.
Since 1988
Two for the price of one.
Tip 1: Hide a spare ignition key (and alarm fob) somewhere inside or outside your motorhome where no one will find it.
Tip 2: Don't post on this thread where you hide your spare ignition key::bigsmile:
Dec 23, 2007
4,077
6,547
Wirral
Hobby Van Kenobi
The best tip ever-tell other motorhomers about this site:thumb::thumb:
duetto owner
216
north surrey
hi top
in first year
take a screwdriver to remove and replace vent covers. our first mistake on our first trip out.
Hopesy
76
South Gloucestershire
Coach built
A sensible one........ this last weekend i rolled the van off the ramps without checking first and smashed a bottle of red wine on the carpet...doh.. when we got home wife put the carpets in the bath soaking them in cold water and the stain was gone after a short while:thumb:
Pammy
Aug 3, 2007
881
152
Mansfield
AUTOTRAIL CHEYENNE
3 years
Our RV is on permanent hook-up at home so I put some ice cubes in a tuppawear container in the freezer. Everytime before we go away I look in the container and if I find that the cubes have turned in to one solid mass of ice then I know that at some point the freezer has defrosted and froze up again which tells me that the frozen food now needs to be discarded.
Pammy
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
Pammy
i had to think a little but that is clever:thumb:
Boo
633
4
A cls
9 years
Should have just poured white wine on it :thumb:
My top tip is: if your grey tank is full and you want to empty it later (cos its late or your too idol.................open your backwater valve and your grey tank and syphon some into your black tank (or vic versa) :thumb:
Boo
2,364
10,282
Boo
I guess that's only practical if you have three valves.. one on each tank and a main dump valve..
Mine only has one on each tank with a common outlet, I could blank it off , but that would leave a lot of black stuff in the outlet line which would pour out when you removed the blank before dumping .. :Doh:
strathspey
62
4
North Yorkshire
4 years
To avoid driving off with mains cable still attched
To prevent the possibility of driving off with the electricity mains cable still attached to the van, I place a small flower pot, marked with a 'lightning flash' over the gear lever whenever I connect the mains cable.
11,934
9,106
::bigsmile: Hi all I agree with all the previous posts :thumb: but the best one I know is build your own van :thumb: no one to blame then if it goes wrong :ROFLMAO: except yourself :thumb:::bigsmile:
If you forget to pack something remember there will be shops nearby :thumb: ENJOY & get using your van :thumb::thumb:
terry
champers
4,224
8,511
Skegness, UK
Frankia i650 FD
Since March 09
Fairy Power
For those stubborn sticky labels on the bottom of melamine dishes / plastic objects that you just cant get off :Doh::Doh: try the Fairy Power Spray its magic, also good for cleaning the oven and everything else too ::bigsmile:::bigsmile:
656
1,052
290
The universe
get the Motorhomes Check List Book. Bloody marvellous
bald eagle
4
here,there and everywhere
coach built
since 1998
my top tip is always have a candle on board,now don't get the wrong idea.
Can be used for sticky curtain tracks.
Squeaky cupboard and locker hinges.
Draw runners and the channel on your roll out awning
and also the pull out bed runners, the list is endless.
Using this method is much more cleaner than spray cans
regards
bald eagle
barryd
1,143
109
Yorkshire Dales
Since May 08
Fit a scooter and rack (if you can) especially if you have an Arthritic Knee like I do and cant walk very far. I love ours and it gets you down all those little alleys and streets you cant explore in the van plus you just park it where you like!
Elvis
294
45
London
Coach Built
Since Nov 2008
ooops
Remember that you haveto take your vent cover off (most models) or you water heater wont work!!
Took us quite a few trips to figure this out!!!! :ROFLMAO:
