Yes another battery question block leisure batteries opinions please
East Sussex
Trigano Tribute
Since 2017
High looking to change out my single 110amp hab battery in our Trigano tribute for 2 new batteries.
I’ve seen the following, as they are more square I can fit them in easier.
Opinions please.
You could buy a lithium battery for less than two of those !
Agreed. You can get a good 120Ah Lithium battery for the price of those two and have the same capacity, less weight, and a much longer life:
If would be cheaper to fit 3x 80ah Gels rather than 2 x 110ah.
Before you go ahead with Gels you need to make sure your charger a proper gel setting with a correct absorbstion phase for Gels.
Wow those prices are good 👍
Don’t think the wiring in my van could take the power a lithium would pull from the alternator.
Although if a lithium or any battery for that matter is fully charged via my solar panel before setting off surely there wouldn’t be much of a problem.
If your van is a 2011, it wont be a euro 5 or 6 so will probably put out a constant voltage of 14-14.4 volt wont it ? .
Its the euro altermators that cause issues with lithium. And a good b2b charger can sort that and supplement your solar.
The Lithium can take pretty much as much charge as you can throw at it.
