Working out inverter capacity for bike-battery charger (1 Viewer)
Jan 18, 2019
532
908
Cuesta Blanca, Murcia, Spain
Hymer Exis
Will someone check my working out, please ?
I have a Shimano charger that is rated "100-240vac at 2.5amp" input and "40-44vdc 4.4-4amp" output
W=V * amps, 230*2.5=575w
So at a minimum I need a 600w continuous output inverter.
That right?
18,023
48,095
I think the power consumption is around 250W. The 2.5A input will be at 100V and as a check the output will be 40 * 4.4 which is a bit under 200W. Not much power will be lost by the charger (unless it gets very hot in use) so the actual figure is probably between the two figures.
You could probably get away with a good 300W pure sine inverter but 500W might be safer. :)
I wouldn't mind betting 300W would be enough on the basis of under 200W output.
600W should eat it. As PJ said, pure sine wave is good policy.
Nigel Crompton
Jan 18, 2019
532
908
Hymer Exis
Would it be worth removing the moulded-on plug and putting a new one on with the outer insulation stripped back so I can use a clamp-meter to measure the actual current draw (at various stages of the charging process) ?
Thinks: Why didn't I think of that earlier ?? :rolleyes:
43,329
49,446
A bit extreme!
43,329
49,446
You could make a short extension lead using individual wires.
It could also be used for fault finding unusual load faults.
You still really need maybe 50% more capacity to prevent the inverter working hard and the fan constantly running, or overheating if no fan.
Sep 23, 2013
2,585
8,773
Lincs
Globecar Campscout
A charger with an input voltage range as wide as that should be ok with a Modified Sine Wave inverter, although it may buzz a bit.
Depends on what else you want to use with the inverter. Pure Sine Wave is more expensive, has slightly higher conversion losses but is more versatile & you can plug anything in without worrying if the inverter will damage it.
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
My bike chargers always seem to surge at first switch on. Do they have any significant induction load at startup which could throw a low powered inverter?
Apr 22, 2013
911
661
Cotswolds
Bailey Approach 625
Since 2011
My Bosch one doesn't quite the opposite. It hangs around for 10 to 20 seconds measuring the state of the bike battery before starting to charge.
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
Mine are Bosch, similar about the thinking about it and then a definite surge. Maybe I will get a meter on it next time. It was only a query on my part based on an impression as I am next to my Victron when I plug them in.
