ShiftZZ
Measure the ones that you already have and do a search for that length online. You might also consider just buying the rubber and replacing those - not a difficult job. The A class screen will almost certainly have bigger bladesAre standard fiat the ones that fit an A class?
No difference between blades for LHD or RHD.They have in the past as Lenny says the hook makes them universal. If you are LHD then they are a special available from Bosch.
There is with aero blades - unless you get the Bosch onesNo difference between blades for LHD or RHD.
Not on my van, I'm LHD I just fitted standard aero blades.There is with aero blades - unless you get the Bosch ones
yes, all our always haveCheck the fitting most A Class use the universal hook.
Their 'flipenfloppenmuckenspreden' qualities are different I believe!Not on my van, I'm LHD I just fitted standard aero blades.
How can there be any difference.?
A lot of them are fitted a single way. I bought a pair for the last van which had the aero bit the wrong way around due to the van having LHD wiper pattern and had to return them. I then got Bosch ones as they are the same both sides. This van I bought the rubber and simply replaced that. A lot cheaperNot on my van, I'm LHD I just fitted standard aero blades.
Standard blades or aero blades, if standard you just need to adjust them.I just fitted some Lucas blades and they are rubbish, they miss on the middle section, whereas the previous cheap Chinese rubbish were fine until they split after a few Highland winters.
The ones I bought could not be fitted the other way round. I tried. The pin for swivelling was in the wrong position. Design may have changed then, or Eurocarparts simply provide crap.A bit like Euro lites beam converters I used to sell LHD ones for 3 times the price of RHD the only difference was the instruction for where to fit them, my buy price was the same.
Aero bladesStandard blades or aero blades, if standard you just need to adjust them.
We put tennis balls under our wiper arms to stop them compressing and sticking, weather isn't an issue as we store ours indoors.I always remove mine when at home. Keeping them away from UV and the weather makes them last longer.
Half a wine bottle cork works. And, if you forget to remove it, hopefully won't cause any damage.We put tennis balls under our wiper arms to stop them compressing and sticking, weather isn't an issue as we store ours indoors.
