Windscreen washer
stoke on trent
rv
im a newbie
hi all have asked this before with no luck dies anyone know where the windscreen washer are fed from or fused 2012 ducato can't find any feed wondered if it come direct from ecu which I have had problems with
Are you sure that the filter in the bottom of the tank is not blocked. Does it sound like the pump is running?
Just changed my pump
Fuse 09 under bonnet -( 07 Ducato maxi) labelled by Fiat as Headlamp washer
The fuse in mine was fine
so took pump out applied an external 12v supply the pump failed to work and just got hot
£25 to replace from a Car Spares Shop (for me PCS in Clay Cross)
capster1958 If the fuse and relay are ok , it could be worth checking that the multiplugs (front and rear) are all pressed fully home on the Body Control Module (BCM) unit.
The wiring for the washer pump motor showing the fuse and relay connection to the BCM under dash fuse unit can be found and down loaded in the Motorhome Technical Articles (on page 3 , Fiat Ducato X250 power supply and headlights) ) of the Resources section that is in the top (blue) line of this page.
thanks all for your replies sorry took so long to reply but been away and don't like meddling just in case. To GeoffnDee it was t17 relay that was missing had trouble with ecu last year think auto elec as put it in t05 by mistake does anyone know what t05 feeds. Many thanx for all your help
Thank you again what does the compressor run as I have not got t05 relay in at present but can get 1 if needed
