- May 5, 2022
- 2,043
- 15,445
- Hymer B778 PL
- Since 1992
Do you mean pivoting down one like in a car or van or a tinted strip internally along the top of the windscreen or an external one that fits just above the windscreen?Does anybody have a suggestion for a windscreen sun visor for an A class motorhome. The ones i can find on line are only long enough for cars.
Thanks in advance.
Sorry. Poor explanation. The tinted one across the top.Do you mean pivoting down one like in a car or van or a tinted strip internally along the top of the windscreen or an external one that fits just above the windscreen?
It is a thought.Maybe the guys that do window tints can do you just a strip along the top of your windscreen from a roll of tint.
I tried it and no joy.Maybe search for hgv /Truck . Sun strip
That is one of those petmet type ones that is fastened at 90 degrees to the windscreen.Have a look at www.magnumvs.co.uk they may have something or be able to help. (they do list a 2025 wide sunvisor , but it is for a MAN Truck)
Unbreakable have been around for yearsThat is one of those petmet type ones that is fastened at 90 degrees to the windscreen.
They do however have what they claim to be unbreakable side mirrors.
Hence the reason for a sun strip. Our unswept area is about 14 inches.Before fitting... check..
I was going to fit a sunscreen on the windscreen of my Ducato, but was advised that if it covers ANY part of the swept area it would fail the MOT ... when I checked the swept area it almost reaches the top of the screen, so no space for a sun strip ..
Cannot see the swip of the wipers on the screen if they do reach the top of the screen and it does not effect the visibility you could consider shorter wiper blades to allow a vinyl sunscreen remember there are legal stipulations on tinted screens ans windscreen usually meet the maximumThe top of the screen is quite high. You can lower the sun visors but it resrticts the view. You can also lower the night blind a bit but this reduces vision and cannot be lowered whilst driving for safety reasons.
View attachment 797122View attachment 797123
We have drop down visors inside but the restrict the view. Driving down the road in the lovely valleys of France and Spain, all you can see is the road and not the mountains beyond.Are these what you are looking for, we fitted them to the underside of the drop down bed. They can be adjusted
to the rake of the windscreen.
I can’t remember where we got them from but I’ll find out if anyone is interested.
I'd be interested if you could find out.Are these what you are looking for, we fitted them to the underside of the drop down bed. They can be adjusted
Yes. Mirror shades. Aviator cool dudes.How about a quality pair of sunglasses.
Fit ANY size of windscreen and take seconds to remove when not needed.
I saw these on the Stedall website when I was looking for hinges the other day.I'd be interested if you could find out.
I had them and they didn't change when driving, they only worked when the sun was shining on the lens..Yes. Mirror shades. Aviator cool dudes.
Prescription photochromic ones from Spec Savers.
yes it is a total itv failure here as well. I got pulled years ago on a tranist connect & had to remove it.Before fitting... check..
I have prescription sunglasses , darkest tint legally alowed,No;3 , & at times here in the sun they are so clear that you think you haven't even put them on , yet look down & you cannot see the dash, sat nav, cameras. wife sitting next to you & god forbid when the "lights on for tunnel" sign appears you forget to lift themHow about a quality pair of sunglasses.
buy two & join in the middle/to one side/somewhere.Both of those are likely cabdidates but i am not sure 2m is wide enough. The van is 2.3mts wide without the mirrors.
You need transition lenses. They work behind a windscreen.I had them and they didn't change when driving, they only worked when the sun was shining on the lens..
Photochromic lenses work in UV light, which most car windscreens block out.
