As my 2x gel batteries( Exide 85ah) are declining I will soon be installing 2 x Sterling 100ah Lifepo4. In anticipation I want to install a 30a BtB. Space is tight in the James Cook so likely to be a Votronic but if I can squeeze it in then a Victron Orion( as I have other Victron kit and rate it). Two stupid questions please. 1. The existing wiring to/from the split charge relay which I will replace is 25mm. So can someone recommend a good crimper( and good value) for the 25mm cable uninsulated terminals I will need to crimp ( including to additional fuses).
2. The Victron has terminals for pins on 16mm max cable. Is there such a thing as an uninsulated terminal for 25mm cable but with a 16mm pin? Or will I have to buy with a 25 mm pin and cut down to 16mm with , say, a dremel? Thanks.
