wotme
What tyres should I buy for my 2007 Fiat Elnagh 3.5 ton coach built. The size is 215x70x15R but what manufacturer should I chose that builds tyres specifically for motorhomes
Continental vanco from Black circle
My michilen Agilis are ab fab with loads of grip on wet grass/muddisappointed with my Michelin Agilis. Won’t buy them again. Poor traction, and quick wearing.
I totally agree the camper tyres aren’t very good. 2 years and 20000 miles and the fronts have pretty much had it. I have never been impressed with the grip they give. I will be putting vandisappointed with my Michelin Agilis. Won’t buy them again. Poor traction, and quick wearing.
Agree Michelin camper are the worst tyres I've ever had fed up with the traction control cutting due to lack of grip and wear rate is high also not forgetting the hard ride.disappointed with my Michelin Agilis. Won’t buy them again. Poor traction, and quick wearing.
That was also my experience. Much h prefer the continental sdisappointed with my Michelin Agilis. Won’t buy them again. Poor traction, and quick wearing.
I find hankook very good.
These are what we decided on, having taken advice from Continental.What tyres should I buy for my 2007 Fiat Elnagh 3.5 ton coach built. The size is 215x70x15R but what manufacturer should I chose that builds tyres specifically for motorhomes
That is the rating regardless of pressure.My tyres state weight rating of 116 Q at 80 psi on the side walls. Does this mean they are not rated for the stated weights at less than 80 psi?
Sounds like you work for Michelin, my fronts were down to 4.5mm at 14,000 miles, and the grip is atrocious.I have Michelin Agilis 225/75/16/CP tyres on a 3500kg fiat/alko motorhome.
35,000 miles now in 5 years and just checked and find no issues and still 4mm of tread across all 4 tyres.
I did do a front to back swap at around 20k miles.
I run them at 5.5 bar as recommended by Hymer.
I have found no grip issues and on the rare occasion I have had to stop in anger, they have performed well. - The ride is on the hard side.
We went up a size from 215/70 15 to 225/70 15.
Decided against Michelin Agilis Campers because of poor reports on them and these replaced our Continental Vanco Campers
A very comfortable ride with lower pressures, though they can be inflated to 75psi if needed.
I found a good price online, printed it off and went to my local fitters (Savoy Tyres) and asked if they could match it. We paid £115 per tyre but that was two years ago.These are the ones we have decided to buy.Did you get a good price anywhere
