What size Generator (1 Viewer)
Jim et Lou
216
119
Sheffield
Coach built
I am new to this
I am looking at getting a generator, but I know nothing about them at all. So, could any of you guy's advise me as to what size I would need. Thank you in anticipation.
Jim et Lou
Jim et Lou
216
119
Sheffield
Coach built
I am new to this
I want to run the internal lights (SMD's) fridge and 240 v tv + battery charging
maz
Jan 26, 2011
4,460
7,740
Bizeljsko, Slovenia
N+B Arto
Since March 2011
Hi there. The lights will run off the battery anyway. If the fridge is a normal motorhome 3-way one, wouldn't it be easier and more economic to run it off gas when off hook-up? Getting a 12v TV would also be easier (and quieter) than running a generator when you want to watch TV. You could run a 1kW suitcase generator to top up your battery when necessary but have you thought about getting more/larger batteries instead. Depending on your usage and planned length of time off hook-up, they might be enough by themselves. Or you could always add solar panel(s) to top up your batteries (late spring to early autumn in UK anyway). HTH :Smile:
Jim et Lou
Jim et Lou
216
119
Sheffield
Coach built
I am new to this
Thanks Maz, I think you are right I do not do a lot off EHU so would probably be a waist of money. Thank you for taking time to help :thumb:
peter H
1,313
665
Neath, South Wales
Low profile
Nearly 4 years
I predict that with in 10 posts to this thread it will have morphed into a Rec versus Yellow debate.
(I carry a 2kw gennerator because it's the largest I can physically handle into and out of its storage position under the bed.)
And I'm not telling you what colour it is.
Peter
camcondor
1,034
480
East Midlands
So many people seem to be keen to "talk" someone out of having a generator.....:Eeek: I don't know why, as a generator is really an amazingly useful thing to have, not just for motorhoming........if you want one, and can afford one, then buy one and don't listen to people who constantly want to know why you can't get a different tv, use this or that differently etc. different strokes for different folks and all that :Eeek:
I bit the bullet earlier this year and bought the Honda eu20i, its absolutely fantastic and because it produces pure sinewave power, delicate electronics are safe as well. You can certainly buy cheaper, but I daresay not better. KIpors are a good bit cheaper but the quality is obviously not the same; Hyundai generators also get reasonable reviews and one of our trade members offers Funsters a discount on them.
However, as with most things you get what you pay for. I am really glad I bought the Honda.
Haha Red vs Yellow it is I guess :) Nothing against Kipor, though, I just prefer my Honda!
maz
Jan 26, 2011
4,460
7,740
Bizeljsko, Slovenia
N+B Arto
Since March 2011
Because in the OP's case, he would have been running a generator constantly to power his fridge and watch TV! Hardly practical. :RollEyes:
I answered the post with what I consider to be the best advice for the particular circumstances quoted.
Steve
1,613
2,062
Compton Berkshire
on and off for 40 years
All good points to bear in mind, don't forget WEIGHT! some vans are very near their limit and people have no idea what the weigh.
Steve
ps one x geny = 50 cans of beer:roflmto:
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
I wanted a small genny for topping up batteries. We don't do TV, have 2 leisure batteries, a 1kw inverter and solar power, so a 1kva ( actually its 1.25kva) unit was big enough.
We didn't go for red or yellow, we got a pale blue one.
Easy to pick up and store, easier to start and very quiet.
Its an SDMO Booster 1000.
Allan
tinkering
222
1,105
dorset
Gennys
:Smile:The first rule in this Motorhoming lark is Keep it Simple.
Your very nice van already has everything in it that you need.
It will have a battery charger ,quite capable of keeping your battery charged
your water heater will be powered by Gas and 240 volts, the fridge, Gas 240v and when the engine is running 12 volts DC.
I have a Honda eu20i 21 Kg one 110 amp battery 24 Kg, I also use a 600 watt inverter the inverter is used to power a laptop/Ipad/mobile phone/19 inch lcd tv.
When the genny is connected to the van it powers the water heater and fridge (why use precious gas) as well as charging the leisure battery, its also used to power a 1800 watt hair dryer,(not mine:Smile:) and a 240 volt 600 watt electric kettle, as well as all the stuff already mentioned.
I also have a 80 Watt Solar panel:Smile: if your lucky 4 amps(9am to 3pm)
I always carry my own luck, its a Honda:thumb:
Cheap no good...Good no Cheap:thumb:
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
Aug 30, 2012
4,270
11,305
Home of the war horse
burstnar T640
We have a 750watt kippor
I have used it about 3 times in 2 years and only carry it in winter months just in case we need a top up it will just run our on board charging and a 500 watt fan heater
Do I need probably not I could just start up van and recharge that way
But its nice to know its there just in case
As I found out in -5 at spring newark show
Dec 28, 2011
2,426
2,769
Stokesley, North Yorks
JoaCamp75Q by Pilote
Still learning since 2010
I carry a 1kw genny for the main purpose of SWMBO being able to use her 800w hair drier/curling thingy when we are off hook up.
It has been used more by my brother-in-law to charge his cheapskate caravan battery because it would only last a day and then go flat. I have persuaded him to buy a new one.
I have a solar panel, 2x110ah batteries and gas.
All the appliances run off 12 volt, 240 volt or gas, or a combination of all of them as needs dictate.
In two years I have probably used the genny approx. four times for my own use, and never to charge the batteries.
It is a nice security blanket feeling to have it, but I have the load capacity to carry it. If not, it will be left in the garage. I'd rather have the 50 cans of beer. :winky:
camcondor
1,034
480
East Midlands
But it was not an answer to the actual question asked, just your opinion on what the OP should do....... And if the OP (or anyone else) wants to watch a Tv and power a fridge with a generator, that is their decision to make, not yours......:RollEyes: looks like another thread might degenerate into a popularity contest by the look of it.
Actually, very few people "need" motorhomes, either, but choose to have them - the same can be said for generators. They are superb pieces of equipment, so useful, perhaps underused but if you want one, get one.
3,341
5,359
Pakefield, Lowestoft, Suffolk, UK
Looking
generators
[HI]So many people seem to be keen to "talk" someone out of having a generator.....:Eeek: I don't know why,[/HI] as a generator is really an amazingly useful thing to have, not just for motorhoming........if you want one, and can afford one, then buy one and don't listen to people who constantly want to know why you can't get a different tv, use this or that differently etc. different strokes for different folks and all that :Eeek:
I know why, they don't want to be next to someone using one.
maz
Jan 26, 2011
4,460
7,740
Bizeljsko, Slovenia
N+B Arto
Since March 2011
How long have you been a member of Fun? Since 2007? And you still expect all posts in a thread to specifically answer the original question? :ROFLMAO:
All info or advice given was with the best of intentions. Of course the OP can buy a generator if he wants to. However, if he plans on running it constantly to power a fridge he will become very unpopular with any neighbours. :wub:
Any thread degeneration into a 'popularity contest' is at your instigation. :RollEyes:
camcondor
1,034
480
East Midlands
I do expect questions to be answered, yes, quaint perhaps, but that is the nature of my profession.
Of course it was. Your good intention did not answer the actual question though, and such threads generally then descend entirely into personal opinions about whether someone should own or buy the item, in this case a generator, or not.
BTW The noise nuisance depends on the generator of course and how long and when used. If someone wants to run a fridge full time on a generator, they may bother no-one at all, depending on where they are parked up. They may also find that their generator "vanishes" in the small hours as gennies used all night like that tend to attract thieves who travel with bolt cutters etc to make off with said gennie. ::bigsmile:
As to instigation of anything, i have not done so. Merely remarked on the fact that it was likely to happen. Not quite the same. :Eeek:
camcondor
1,034
480
East Midlands
Well don't be. No-one is forcing you to be there! I can hardly hear my Honda eu20i running when I am in the van, let alone if the TV or radio is on, so its unlikely it will be bothering anyone else. Added to which, I would never run it all night.
FULL TIMER
795
717
NORWICH
SELF BUILT IVECO 75E17
I have a small Hyundai HY1000si genny, only use it at rallies where there is no hook up, an hour in the morning is normally enough to top up the batteries and charge the laptop etc, However I can't see any point in using one to power a fridge etc bearing in mind the cost of petrol.
Jan 3, 2008
3,341
5,359
Looking
Of course you can hardy hear it in the van with the tv or radio on. But if you can still hear it what about the people in the nearby van with the window open trying to read or just enjoying a quite nap in the afternoon.
I have in the past been parked on an aire with not a great deal of space when a neighbour started a generator during the day which was so loud it did disturb us and others. In the end, after several people complained it was turned off. Only to be turned on again that night. which lead to quite a lot of shouting.
Not everyone is as conscious or considerate of others as you apparently are and some have cheap noisy generators. As for not being forced to be there, does that suggest that you think that the majority of people who are disturbed by a generator, wherever they are parked, aire or campsite, should move off so that the one person with the generator can use it as they wish. I hope not.
Your generator and the thoughtful considerate way you use it night not cause annoyance but in my experience (and I can only report what I have actually experienced) most generators I have encountered have been noisy enough to disturb others which is why I, and I suspect, may others don't want to be parked next to someone using one. Perhaps I haven't experience the totally quiet ones that don't disturb other people, but if I had I would not know about it would I.
camcondor
1,034
480
East Midlands
People annoy other people all the time - often for trivial reasons - unfortunately this is a small island and we can't all tiptoe around whispering because someone might be annoyed for some reason. Noise is a fact of life. Alot of campsites do have rules about generator use and quite rightly so - but just as you feel you have the right to absolute silence on a campsite,so others feel that using a generator is their right too, and many, many campsites are blighted by the sound of horrible, hooligan, yobby screaming children totally unsupervised by anything resembling an approriate adult.
Choice: generator noise or screeching out of control kids ? I know what I would prefer! Generator wins no contest!
If you want to avoid generators entirely, book on a campsite that bans their use. Just as one could book an adults only campsite if you want to avoid screaming out of control children entirely. If you book on sites that allow both, then you take the chance that they might annoy you.........but hopefully not to out of control levels.
Having said that, many parents are responsible and stop their children from behaving in an anti-social fashion, just as many generator owners are considerate of those around them and only run the equipment at reasonable times or for short periods.
There are good and bad all over, and unfortunately not a huge amount of space on this little isle to be able to avoid those you do not like all of the time.......:Eeek:
maz
Jan 26, 2011
4,460
7,740
Bizeljsko, Slovenia
N+B Arto
Since March 2011
Well, expect away! ::bigsmile:
And just how have your posts 'answered the actual question'? Nowhere have you advised the OP what size generator he would require. Your first post was just your personal opinion on Honda vs Kipor vs Hyundai. The others have just been your personal opinion that generators are wonderful - regardless of their suitability for a particular use. :RollEyes:
:yawn:
camcondor
1,034
480
East Midlands
:yawn:
My post was in response to the (expected) "why do you NEED a generator" brigade, so it responded to an issue raised in the thread as did the one comparing the different makes- someone mentioned the yellow vs red argument.
Not sure why I am bothering to respond to the thread police :yawn: If you want to slag me off further, take it to PM.
It would just be nice to have a generator thread where people are not inclined to leap on and demand to know why the person wanting the generator NEEDS it because they have batteries, solar panels yada yada yada and it makes a NOISE :Eeek:
Yes, generators are fantastic. Not everyone wants one (clearly).
:restmycase:
3,341
5,359
Looking
generators
Never did I suggest for one moment that I think I have a right to absolute silence, to say that I did is absolute fantasy. Neither do I need advice from anyone on what type of site to book, particularly since I rarely use campsites. Of course I accept that there are considerate generator users as I thought I made clear. Never did I suggest that you were anything other than considerate and I don't really understand why my saying I don't what to be next to someone with a generator (considerate or not)has caused so much steam to escape from your collar.
I think I will just leave it at that.
Jul 1, 2010
3,204
33,639
SW Northumberland
Hymer B 588 DL
Since September 2010
Motorhome FUN the clue is in the name its such a shame generator threads provoke so much negativity. Lighten up and enjoy life :ROFLMAO::ROFLMAO::ROFLMAO:
camcondor
1,034
480
East Midlands
The only steam generated is from you.......you are, to put it in psychological terminology, projecting...... You went off like a rocket about how people using generators were generally upsetting people wanting peace and quiet etc.......
All I did was point out that there are alternatives if you are so anti-generator, not that you HAVE to do anything at all. But people are still entitled to own and run generators just as they are to have children or pets which may be perfectly well behaved or nasty, anti-social people just like the parents /owners. It takes all sorts. A bit more tolerance perhaps for the fact we are all different? :Eeek:
maz
Jan 26, 2011
4,460
7,740
Bizeljsko, Slovenia
N+B Arto
Since March 2011
:restmycase:
Um, you were the one who started the so-called 'slagging off' - though I don't see it like that. ::bigsmile:
So apparently it's ok for you to respond to an issue raised by the thread without answering the exact question posed - but not me. :RollEyes:
Incidentally, I do have a generator - so maybe you're not so clear on the facts as you'd like to think. I use it to charge my batteries when we've had a spell of bad weather that the solar can't keep up with. No way would I run it continuously to power the fridge. That would just be silly. :Smile:
