- Oct 13, 2016
- 1,067
- 903
- Mercedes Hymer B680
- Been moho’ing for a time now
as above, I've just cleaned all the tank and pipes, now what purification tabs do you use ?
But babies don't have a stainless steel boiler which Milton causes problems with. Cost me over £500 to fix the pin prick leaks on the Truma on my previous motorhome.Some use Milton purification tablets. If it’s good enough for babies?
Phil
If this is the case, I would be careful about using it to sterilise babies bottles as well.But babies don't have a stainless steel boiler which Milton causes problems with. Cost me over £500 to fix the pin prick leaks on the Truma on my previous motorhome.
They'll on,y do that if you leave it standing and use a strong mix. Couple of drops milton and rinseBabies bottles are plastic, not stainless steel. And they don't have Milton solution in them all the time, unlike a Truma boiler.
John's Cross told me the probable cause of the leaks were the use of Milton type purifierers which I think they said attacked the slight impurities in SS, which caused the pin prick leaks.
You need more than a couple of drops to make any difference for cleanliness of the whole water system in a motorhome, unless you are a believer in homeopathy.They'll on,y do that if you leave it standing and use a strong mix. Couple of drops milton and rinse
They'll on,y do that if you leave it standing and use a strong mix. Couple of dropBabies bottles are plastic, not stainless steel. And they don't have Milton solution in them all the time, unlike a Truma boiler.
Actually you don't. It's strong stuff. You need about 5mg per litre of free chlorine for an hour to kill any bacteria.You need more than a couple of drops to make any difference for cleanliness of the whole water system in a motorhome, unless you are a believer in homeopathy.
The OP was asking about continual use for "purification", not just used for a quick clean then flush.
Better than sterilisation. That doesn't sound good.What is a "purification tab"?
Sounds a tad religious to me...
JJ![]()
Sounds good advice to me.Milton is what Swift recommended, but use only as described ie quantity and only leave in for 15 minutes max then flush through until no taste at the taps, 3 full flushes I did. Never caused our van any problems in 9 years
And Truma's instructions also states when cleaning and sterilising that "Products containing chlorine must not be used".Truma recommend....
"Add 2 litres of white wine vinegar to 10-12 litres of water into the tank. Open the taps to draw through the system including the boiler, leave for 4-5 hours and then flush through. " Simples.
Terry
Yes, I read a post on this some time ago from a chap that worked in the water industry. He said that there were sufficient purification chemicals in domestic tap water so nothing else was required.Non.
All fresh water is fine and it's full of chorine to keep it that way.
It will be fine. Hydrogen peroxide is an oxidising agent that disinfects water just like chlorine.Many thanks to all who answered, after reading all the posts and various company blurb I went for Elsil, time will tell if I’m wrong ?
