What mobile data system do you use?
596
Banned
RV
10yrs plus
OMG ?. I was inspired by a forum member to go mobile data instead of antiquated satellite and aerials, you know the things you have to drill holes in your van to fit, you can see them in most museums old tech display rooms. Well I did a test today, I am using 3 mobile, I have an Apple XSMax that is meant to be state of the art, well it was until thy launched a new state of the art one last week, anyway I did a speed test on my phone as it was, then linked it to the dongle thing I bought that also has a 3 SIM in and this was the result, I can attach 32 devices to the dongle thing and it has 40GB a month, as I don’t watch TV it will be used mainly on this forum, I can get more GB if getting short they said (y)
This is the dongle thing Amazon product ASIN B074XKDB4G
This is phone result which is the lower one and dongle result higher, I don’t know what it means but apparently higher is better, so in future will dongle my phone to allow quicker posting ?
SO WHAT DO YOU DO or are you still into screwing in your van?
I use a huawei 5577c mifi with a puck mimo aerial on the roof. speeds often compatible to home broadbad on three. backed up with unlimited data on my samsung galaxy s10plus through vodafone
I simply tether to the phone. 30gb a month data works for me. Includes the Netflix stick for TV. Works well for iPad etc etc as well
I can do that but the dongle thing for whatever reason seems so much faster. The only downside to the dongle I got is you can’t attach an aerial, but with the speeds it gets maybe don’t need one. Will test it more and report back, think 5577 takes an aerial but much slower download and upload speeds half of the one I bought I think.
5577
SPECS:
Download speed: 150Mbps
Upload speed: 50Mbps
Sim Card Size: Standard Sim Card
Dimensions: 9.5 x 5.5 x 1 cm
Battery life: 6 hours – 300 hours standby
Share: Connects up to 10 WiFi enabled gadgets
Amazon product ASIN B011YM0OXU
5885
Huawei Mobile WiFi Pro 2 is a new 4G pocket router supporting LTE advanced networks.And power bank with larger
battery up to 6400mAh. With HiSilicon LTE Cat6 Chipset, Huawei Mobile WiFi Pro 2 could achieve peak download speed up to 300Mbps and upload speed to 50Mbps. Up to 32 WiFi-enabled devices could access internet through the wireless network from Mobile WiFi Pro 2. There is one Ethernet port(RJ45) to provide network for desktop.
Huawei Mobile WiFi Pro 2 E5885 Technical Specifications:
* Product type: 4G Portable Router/4G LTE Mobile Hotspot
* Category: LTE Cat.6 pocket router
* Chipset: Hisilicon LTE Cat6 chipset
Huawei E5885Ls-93a supported frequency bands:
- LTE FDD: B1/B2/B3/before/B5/B7/B8/B20/B19
- LTE TDD: B38/B40/B41(2555-2655MHz)
- UMTS: B1/B2/before/B5/B6/B8/B19
- GSM: B2/B3/B8/B5
* LTE Peak download speed to 300mbps and upload speed to 50mbps
* Support 3G UMTS/DC-HSPA+ 900/2100MHz
* UMTS speed up to 42.2Mbps
* WLAN: IEEE 802.11 a/b/g/n/ac, dual-band(2.4GHz & 5GHz)
* Support up to 32 WiFi-enabled devices
* SIM type: Micro SIM
* Ethernet port: Single LAN port(RJ-45)
* NFC function, Zero configuration for Wi-Fi, High speed Ethernet
* LED indicator: Signal Strength/Network/Charging/Provider/WiFi/SMS
* Number of antenna: Not Specifiedsecurity featuresEncryption (WEP/WPA-PSK/WPA2-PSK)
* Battery Capacity: 6400mAh, can charge other electrical devices
* 0.96 inch OLED display
* Hilink APP 3.0, Media storage and file sharing
* Output: 5V/2A
* Support Windows 7, Vista, Mac OS
We use two sources for data.
1. Use our phones as we have 80 gigs on Vodafone which we can tether to other devices. Use our fire stick plugged into the TV which works well. We have watched Motogp, F1 and other sports events and still had data left at the end of the month so works for us.
2. If nearby wifi is available we use the Iboost.
We have satellite as well but rarely use it nowadays.
This basically is on wet days as watching TV is a last resort.
Phil.
Anyone know the difference between fire sticks and chrome cast, now I have the connection I need to buy something to connect to, will be for grandkids, we have amazon videos and are total Apple users so no android. Thanks
I see my dongle has an Ethernet connection point so will buy an extender box and can get my Hue lights connected as I have some spare bridges ?. It’s also going to give me live view from my Blackview dashcam, maybe even fit in CCTV for security, simple witless cameras like the Amazon Blink are fantastic ?
This sits in my van.
Huawei B525-4G 300Mbps mobile... Amazon product ASIN B06ZZL966QI've got that on EE PAYG SIM
If that fails to find service I swap out with my phone SIM which is on O2.
one way or another i'll be posting on t'internet ?
Well unless I don't have EHU that is as I haven't wires up my little 12v regulator for it yet, so only works on 240v at the moment ?
Off grid last weekend, so I bought access to an available wifi signal ?
How many posts will I get with 40GB? Was going to try that first and if I run out often can upgrade to unlimited but more expensive.
I did look at that with an aerial combination, mine can’t take an aerial, as you say the issue is power, in the end I went for the 5885 as it has an internal battery bank, runs for a full day AND you can charge your phone from it, I think as I only use the van once a year for me the 5885 was the correct decision ?. I can always change and give it to one of the grandkids if no good ?
I use Vodaphone 40Gb a month phone tethering. I am currently at El Berro and getting download speed of 40Mbs. There is free site wifi here but only about a quarter of the speed.
Those who know this place will be aware its about as rural as you can get.
Well I have to say,
I find it funny.
After all this is FUN
Yes you can have fun with Wi-Fi but I don’t think some people realise what you can now do instead of screwing, this is a more cleaner, as in aesthetics and wiring way of doing things than worrying where your next hole will be, my aim is to have as few holes in my van as I can, they have a bad reputation as it is ?
We have a sat dish glued to the van roof. It picks up tv signals in places where there is no data coverage. Likewise we use a dedicated satnav for the same reason
We use a Free sim in a Mifi to give us internet access at home in France and Smartdnsproxy to enable us to watch UK and if necessary, USA tv while in France.
We use 3 sims in our smartphones when in the UK.
deep joy 32 devices no wonder you want 1000k payload
I just use my phone and can tether iPad and laptop to it. Don’t watch tv at home so certainly don’t when away.
I have 20 gig and have not needed any more.
That’s with EE.
That’s with EE.
I have unlimited data on 3 but don't know if tethering is limited will check it out, just wondering if you use speed test, would be interested to know if the tethering speed is the same as your phone, I know when abroad they reduce the speed of the connection when roaming on 3 mobile, something to do with the agreement with the other countries they have agreement with.
For goodness sake, I have just checked and found that perhaps I didn't need the dongle, I have unlimited data on my phone plan and iPad SIM so can tether unlimited to other devices! What the hell! So glad I joined this forum as I would never have known, I have just paid for another 40gb month SIM for the dongle, anyway thanks for the replies (y)
What I found:
"As of 2019, Three no longer uses the ‘all-you-can-eat’ branding for unlimited data and has now returned to calling this ‘unlimited’. You can get unlimited data on a range of price plans from Three, including Pay Monthly, Pay As You Go and mobile broadband plans."
"With Three’s unlimited data plan, you can use your smartphone worry-free for as much browsing, streaming and downloading as you like. You’ll get access to Three’s 4G network with 99% population coverage, and you’re able to tether or use personal hotspot to share your data with other devices. You’ll also be able to use up to 19GB of your data abroad in other countries through the Go Roam offer."
More here, just summarised above https://kenstechtips.com/index.php/three-all-you-can-eat-data-reviewed
Just to put it into perspective, I have 4gb per month and, when I am away, I only use it for surfing the internet (rather than watching tv/videos).
I use less than 1.5gb of my allowance.
tempted to use pigeon post from the loft next door, they're very mobile..:rofl:
but have unlimited data on my phone, so, that suits me..:cool:
Unlimited data on my phone, so just tether to it.
Based on your various posts, it is clear that there is a pattern of impetuousness in your decision making. If I may be so bold as to suggest ‘slow down and take five’!
At this rate you will run out of the allowable post count before you run out of data! ??
Ian
Hi, I don't know if the speed is the same as on my phone as I don't know how to test this. I don't seem to notice any difference in speed when using tethered items either ipad or laptop.
100G on Vodaphone, no limits, tethering allowed. £20 per month, shame they have stopped that deal now. :restmycase: When away, particularly down in Spain we watch films and use about 65G per month ishhhhhhh. :gum:
firestick comes in 2 flavours, the standard firestick that is great in the motorhome to stream films, programmes, video and catchup tv direct to your tv on the hdmi port. i stick with 720p for fast buffer free streaming via the phone or mifi. mine is jailbroken with extra apps giving access to even the latest content and pay per view sports etc
the firestick 4k is a little larger but does the same as the basic firestick but in super fast 4k video. this makes it unsuited to 4g streaming due to buffering unless you reduce video quality back to 720p
chromecast is a casting device that you transmit the video from your phone, tablet or ipad etc. it is not a streaming device with apps on, just casts to the screen
