What isolation switch for solar panels?
NW Surrey
LHD Hymer exsis-i
I'm in the process of fitting a second battery and MPPT controller. At the same time I'd like to fit an isolating switch to enable me to easily disconnect the solar panels. Can anyone recommend a suitable switch please?
Malcolm
Why not just put a fuse in that can be pulled, would be best to have one before the regulator anyway so that the panel connection can be made last.
Martin
With 400w of panel, I used one of these. Switch and fuse in one. They do them at various ratings for you to choose to match your requirements. :)
Do what ever you think you need to do at night?(y)
I have 3 X 150w panels and have no switch, and to be honest, can't think of a reason I would need one?
Thanks everybody. @SuperMike I didn't see a link in your post.
Eddie, there's a school of thought that says leaving batteries on charge all the time isn't particularly good for them. It makes sense to me on the basis that any current in or out results in some activity at the plates, whereas a battery in good condition, fully charged, just sits there. My MH isn't used for 2/3 months at a time, so I'm thinking a short top up once every 4/6 weeks would be better.
I accept there's nearly as many varying opinions about batteries as there is politics though.:D
Malcolm
Malcolm
Luckily that school was closed down by government inspectors, and not before time.
Malcolm
You will always have a drain off the batteries - the charger unit / EBL makes sure of that. If you have alarm or tracker, this will drain the Cab battery and if solar isn't charging the Cab as well, you may need the Hab battery to top this up via battery master or the like.
Thanks everybody. @SuperMike Eddie, there's a school of thought that says leaving batteries on charge all the time isn't particularly good for them. :D
Malcolm
That is what night time is for;)
If you install a Battery Master as well, the quiescent drain of ECU's alarms, clocks, radio's, Navigation systems, tracking systems etc will mean that there is always a drain on the engine battery, that in turn will put a load on the leisure battery.
So a constant state of flux
Personally my camper is plugged into the mains all the time, freezer on, fridge on, wine cooler on, so always ready for the off. I am of the opinion that things rarely go wrong when your using them, its when you turn things off, and shut things down that things go tits up
