What can I use..??? (1 Viewer)
old-mo
Extra Special
16,343
93,692
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
We have two (2) very large Solar panels,, coupled to two (2) 180amp hr batterys (That look like they have come out of an electric milk float, Massive)..
Also we have a "Waeco" Sin Power inverter. (Or should that be converter?:RollEyes:)
My question what size wattage Kettle and Toaster can I run from this set up...
Or should I be looking to buy lower wattage kettle & Toaster etc.. ?
2nd.. Question.... the power points work of the inverter, "But" are they over ridden when on EHU.. and use the site electric...
I`m :sorry2: if these questions sound as if I`m thick....... but I am when it comes to electrics.. :RollEyes::Sad:
Thanks.
Popeye
Sep 5, 2011
7,926
86,461
edge of New Forest
Frankia Platin Plus
On and off since 1983
I`m :sorry2: if these questions [HI]sound as if I`m thick....... but I am when it comes to electrics[/HI].. :RollEyes::Sad:
Thanks.
......and you ain't alone Old Mate...love the van Mo.......:thumb:
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
Since 2012
Thanks.
There is no point in buying smaller toasters and kettles if the existing inverter is powerful enough to run them. You won't have any less water to boil just because you do it at half the rate. In fact, it will probably use a fraction less electricity to do it faster, as it has less time to lose energy to the surroundings.
Of course, we don't know if the inverter is powerful enough as we don't know the rating of the inverter, the kettle or the toaster.
As for how your inverter is wired up wrt the EHU, we can't answer that. Unless you have a default factory setup and someone has exactly the same model and can take a look at theirs...
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Thanks.
Can you see the INverter ? Can you find a label on it (using a mirror) ?
Really you should re-think kettle and toaster. Gas is the best way to generate heat when not on hookup. Your gas tank(s) will hold probably 1000 times more energy than your batteries, which is why cars run on gas and not electricity.
Is your next question "how do I empty the little cassette". A whole new world for you Mo. Welcome to the world of the mortals.
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Thats what dealers are for, they sold you the van, ask them and carry on until you get all the answers you need.
Peter
Says a man gnashing his teeth and muttering "Am I past it ? Have I lost my touch ? How the hell did I let that deal slip through my fingers ?"
Don't be too hard on yourself Peter, he might be ancient but he don't half move fast when he gets the urge. Ask Judy !
old-mo
old-mo
Extra Special
16,343
93,692
Weymouth. Dorset...
Mo,
Peter
I will ask, Peter...
But in fairness to them I think they did explain on hand over,,,, but there is so much on here that it just fuddled my brain and gave me a headache...:RollEyes:
Terry
11,932
9,085
Lincolnshire
Can't remember ;)
Hi Mo chances are the inverter will only power one socket--the others will be powered on HU
Best way to find out is plug in and see what happens ::bigsmile:
IE no HU and see what works :thumb:
HU and then see what works :thumb:
you may well have to switch inverter on :Smile:
try it all out on your drive :thumb:may well be worth taking a pen and pad ::bigsmile:
terry
eddie
8,157
41,270
Taunton Somerset
RV
since 1989
Congratulations on the new van it looks great :thumb:
Inverters! If it is correctly fitted it should power all of your 13amp sockets but nothing else and there should be a transfer switch which will isolate the inverter when the motorhome is plugged into external mains.
As for what you can run, the inverter will give you a wattage say 2000 watts
If that is the case, you can look at a kettle and there will be specification plate (normally on the underside) Top Trade Tip empty the kettle before turning it upside down to check :winky:
Lets just assume the kettle is 2000W so yes you could, in theory use it on the inverter.
However, a couple of pondering points. I always suggest that the rule of thumb workings out AC (mains) Watts to DC (battery) Amps is to divide by ten. So you would use 200 amps of battery power to boil your kettle. OK it won't take an hour to boil it but a couple of cups in the morning, midday, mid afternoon and one before bed and it all soon adds up.
You should only use about 50% of your battery capacity on a regular basis, so you 180 amps to use. If you use up all of your "amps" for boiling water you'll have non left for things like lights and pumps.
Hope that helps a bit
Eddie
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
When you look at all the members discounts available on Fun why bother with any other forum or supplier, you can even get a discount on bog rolls, the list is endless:ROFLMAO::ROFLMAO:
10% discount to MotorhomeFun subscribers on
KVH domes, Oyster satellite, Dometic, Waeco, Sterling, Solar, Strikeback & Growler Security Systems plus much, much,more
Eddie Vanbitz
Ash
Broken Link Removed
There are others as well
and of course me
Peter
old-mo
old-mo
Extra Special
16,343
93,692
Weymouth. Dorset...
Eddie Vanbitz
Ash
Broken Link Removed
and of course me
Peter
And don't forget the most important trader, Peter.. =
*OLD - MO`s* Maids Servicing Centre.... Satisfaction Guaranteed, or your money back...
Mobile, and Many Happy Customers... :thumb:
:winky::ROFLMAO:
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Thanks.
Dont worry about none of that crap Mo Just throw the switch on the dash that fires up the ole---------------------- oops Its a Euro:Doh::ROFLMAO::ROFLMAO::ROFLMAO:
G
43,329
49,446
listen carefully Mo....to make 'toast' you need a frying pan and some cooking oil.
put a splash of oil in pan and place on gas hob, when hot put in a slice ofbread.
when golden brown turn over and crisp second side.
no need to butter as its full of oil anyway. :thumb:
old-mo
old-mo
Extra Special
16,343
93,692
Weymouth. Dorset...
Is That real Toast.. :Cool:
I calls it Fried Bread... :Doh:::bigsmile:
Terry
11,932
9,085
Lincolnshire
Can't remember ;)
Hi Mo are you telling us you paid all that money and the van has not got a oven or grill?::bigsmile:
Terry
old-mo
old-mo
Extra Special
16,343
93,692
Weymouth. Dorset...
Terry
Strange as it may seem...
"No"............. :cry:
Got a pokey little oven, but no grill and No Microwave... :RollEyes::Blush:
Chris
21,054
278,768
None
10 years
Hi Mo,
In our Burstner we took a shelf out of one of the cupboards above the sink and fitted ( nice and snugly) a low wattage microwave.
Might be worth looking at:thumb:
Terry
11,932
9,085
Lincolnshire
Can't remember ;)
Hi Mo,
Micros don't make real toast ::bigsmile:
terry
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
Since 2012
:thumb:
nor cook a pie or yorkshire puds :winky:::bigsmile:
never mind Mo can always loose a cupboard and fit a proper cooker in ---or eat out ::bigsmile:
terrry
Mine's got a US style oven anyway. You can't do any of the above things in it. What you can do is apply a 10mm thick pure carbon layer on side of any food, whilst maintaining the other side completely frozen.
Terry
11,932
9,085
Lincolnshire
Can't remember ;)
Well I have just gone back and looked at the pics of Mo's van and there is no room for a oven unless you put a combi micro one in one of the top lockers ::bigsmile: Infact the kitchen is tiny :Eeek: You will have to eat out more Mo :winky: or get a Ramoska type cooker :thumb::Smile: don't think you can do toast in the Ramoska :Doh:::bigsmile: then again I have never tried with ours ::bigsmile:
terry
