Webasto 3500 D overheating (1 Viewer)
Evildoody
153
59
Aberdeen
CI Mizar Living GTL
Super Geek
A few weeks back, my Webasto heater developed a fault (F10) overheating, so I decided to take it to bits and attempt to repair it myself (probably just the overheating sensor as all inlet and outlet pipes are not blocked. Instead of just replacing the external overheating sensor I figured I have come this far so I may as well service the unit too (15 years of use without one service) :-
20190209_110803.jpg 20190209_115423.jpg 20190209_115436.jpg 20190209_120615.jpg 20190209_121040.jpg 20190209_132317.jpg 20190209_133222.jpg 20190209_133835.jpg 20190209_133840.jpg 20190209_134057.jpg 20190209_134107.jpg 20190218_102043.jpg 20190218_102051.jpg 20190218_102055.jpg 20190218_102107.jpg 20190218_102623.jpg 20190218_102920.jpg IMG-20190209-WA0000.jpeg IMG-20190209-WA0002.jpeg IMG-20190209-WA0004.jpeg IMG-20190209-WA0006.jpeg IMG-20190209-WA0008.jpeg IMG-20190217-WA0039.jpeg
As you can see there is some soot and carbon build up and the burner mesh has seen better days!
I have never taken one of these things apart before, but it all looks pretty straight forward to me. One thing about these German units is that they are expensive and parts are expensive, I have had to purchase the following parts :-
Webasto Combustion Motor Reflector Foil | 9022102A
(old one had seen better days)
Webasto Exhaust Pipe 24mm | 36061296 | 90394a
(old one had surface rust and was split)
Webasto Air Top 3500 or Air Top 5000 Burner Kit 12v | 67984B
(comes with all gaskets, O rings and glow plug)
Webasto Air Top 3500 Outlet Hood | 98651B | 1320323A
(I damaged it taking it apart :-()
Webasto Air Top 3500 Air Top 5000 Overheat Protection | 97265A | 1322831A
(hopefully this was the actual faulty part)
Webasto and Eberspacher Combustion Air Pipe 25mm | 91562A | 36000006
(original combustation air intake pipe was also split)
In addition to the above I have purchased stainless steel bolts, screws and Jubilee clips - so when I put it all back together (starting tomorrow) I should not have rusted bolts, screws, clips etc. if I ever need to take the unit apart in the future.
PS. The only video I found that was helpful and related to my actual unit was in Russian :-
Evildoody
Evildoody
153
59
Aberdeen
CI Mizar Living GTL
Super Geek
More progress made today :-
Gasket_Cleaned.jpgGasket_Cleaned_2.jpgO-Ring_Fitted.jpgBurner_Tube.jpgBurner_Top_Plate.jpgBurner_Top_Plate_w_bolts-p_rubber_grommet.jpgNew_Gasket_Fitted.jpg Almost_reassembled.jpg
Old gaskets removed, new O-Ring fitted, new Burner tube inserted, burner top plate fitted, new gasket fitted and casing reassembled. Now need to fit heat exchanger, overheat sensor, control box, reconnect wiring harness and plastic housing. Then need to connect it all back up and see if it works :eek:. Job for the weekend, wish me luck.
Evildoody
Evildoody
153
59
Aberdeen
CI Mizar Living GTL
Super Geek
Unit refitted, replaced all bolts and jubilee clips with stainless steel ones too, will make the job easier should I ever have to remove the unit again. I also extended the wiring harness.
I had the unit running for over an hour without issue, so all should be good.
I still have some cables to tie wrap in place and I need a new silencer and 90MM heat pipe as they are knackered too.
irnbru
13,514
31,142
Glasgow
Benimar 264
11 yrs
I hope you don't have a dog. Ours kept going faulty with our last van but it was the dog lying in front of a vent blocking it.
Evildoody
Evildoody
153
59
Aberdeen
CI Mizar Living GTL
Super Geek
No, no dog. Definitely a sensor fault in this case. I'd be really upset if I had gone to all this trouble and the issue was caused by my dog :ROFLMAO:
