Mary Alexandr
- Jun 15, 2021
- 1
- 0
- fait lifestyle
We have a Thetford Casette toilet in our Motorhome and recently it has started to smell! Any recommendations?
They will all smell in this hot weather. Double up on the fluid you use, bio washing tablets or toilet additive, that will help, In the longer term fitting a SOG extraction system will help.We have a Thetford Casette toilet in our Motorhome and recently it has started to smell! Any recommendations?
I notice on the label "prevents backups"We have just moved to this instead of bio washing liquid
it is designed for RV black and grey tanks , but am sure it would work as well in a cassette
we have now got odourless black abd grey waste
it really is close to a miracle cure not cheap at around £30 from Amazon but will do dozens of black and grey tanks so even more cassettes
I wonder if it works so well in a black tank because not emptied so often and has time to do it’s magic. Cassettes get emptied and usually rinsed out every day. The chorine in the rinsing water might kill the bacteria. I know there is no need to rinse but I do.I notice on the label "prevents backups"
Liquid laxative......
No worries i dont get quoted very oftenI wonder if it works so well in a black tank because not emptied so often and has time to do it’s magic. Cassettes get emptied and usually rinsed out every day. The chorine in the rinsing water might kill the bacteria. I know there is no need to rinse but I do.
Edit : I meant to quote DavidG58
You may find the smell returns after you have emptied your grey waste.We thought our cassette had started to smell. We'd be driving along and get a whiff of sewer. Turns out it was coming back up the plug hole from the grey tank, not the cassette. We Puriclean'ed our fresh water, then ran it through into the waste and let it sit there for a day. Problem solved.
Do NOT use blue or anything with formaldehyde in as it will kill all the culture that breaks down matter in septic tanks stone dead which a lot of sites especially those that are not on main sewers use.and make sure it is blue, not green.
Being away in the van wouldn’t be away in the van , without a curry.Don’t eat curries when away in the van
thisWe thought our cassette had started to smell. We'd be driving along and get a whiff of sewer. Turns out it was coming back up the plug hole from the grey tank, not the cassette. We Puriclean'ed our fresh water, then ran it through into the waste and let it sit there for a day. Problem solved.
