Water to taps (1 Viewer)
jo10000_6
249
137
South Yorkshire
Hymer B544 Classic
Jan 2018
Hi all
I’ve been rinsing through some water tank purification stuff over the last few days and filled and emptied via the taps no problem.
Just getting the motorhome ready for a small trip over the weekend and lifted the tap to make sure all ok and no water.
Pumps kicks in can hear that straightaway but there’s no water coming around the bit in the picture - usually you can see it swirl around but the waters obviously not getting to that point.
Any obvious things for me to try please.
Jo
Hymer B544 - 1993
TheBig1
17,176
41,118
Assuming you have water in the tank, have you flushed the filter on the end of the tap?
138go
3,276
14,612
Carthago 138
Since 2001
Pumps packed up. The motor is going but not driving the water pumping part or the cleaning solution has affected the pump in some way.
jo10000_6
jo10000_6
249
137
South Yorkshire
Hymer B544 Classic
Jan 2018
Shit !
I deliberated doing it to be honest but the stuff I used was what everyone had said use - puriclean.
This is why I dare not descale the boilers!
One step forward 5 back :(.
jo10000_6
jo10000_6
249
137
South Yorkshire
Hymer B544 Classic
Jan 2018
No I don’t but posted for a few ideas - perhaps things I could try.
Won’t stop the weekend trip but trying to understand what’s gone wrong even if I can’t fix it is usually what i do.
Thanks for reading and responding - I’m always appreciate.
42,966
47,043
Shit !
If you're referring to Qfours post it's only an assumption unless he has a window to another dimension and can see your pump in operation.
It's more likely a simple air lock
TheBig1
17,176
41,118
Sorry what filter on end of tap ?
many taps have a gauze filter screwed into the outlet of the spout which traps all the limescale and debris
6,562
7,425
Manchester
A class Hymer
Since the 80s
First thing I'd do is check if the pump is working, and hasn't got an airlock inside it. It looks like the pump is a submersible type that's in the tank (there's an electric wire going to where the hose comes out of the tank).
To check the pump, unscrew the cap that the hose and wire go through, and lift it out. Separate the hose at one of the joints. Warm the joint with a hairdryer to make it flexible and easier to take apart. Submerge the pump in a bucket/bowl of water, and operate a tap to switch it on. Expect a strong jet of water from the hose from the pump, and catch it in the same/another bucket. If no water jet, tap the pump to dislodge any air bubbles inside it. If still no jet, but you can hear the pump motor, then at least you definitely know the pump is not working.
Edit- just noticed you solved it already
jo10000_6
jo10000_6
249
137
South Yorkshire
Hymer B544 Classic
Jan 2018
Always appreciate a comment, Autorouter- next time I may not be so lucky so your comments will be there for if I have issues in the future. (y)
