water pump unwanted wake up call (2 Viewers)
igcw9170
22
swansea
Hi,
I have just returned from Beziers in my Ci Riviera 181, very hot, got there and back with no problems. There is one annoying niggle though, the water pump seems to have got into a habit of springing into life every couple of hours for a couple of seconds, just long enough to wake you up. I think this is a new occurance as i'm sure I would have noticed it before.
Does anyone know if there is something obvious that I am or am not doing or a way to rectify it?
cheers,
igcw9170.
I
igcw9170
22
swansea
without wanting to sound like an idiot, in the pump or the tank? havent noticed any pool of water on the floor.
dellwood33
878
Newcastle
italian crap
too long
Check the connections to the pump. My CI was the same until I tightened them up. Water was running out via the chassis on my Mizar :Smile:
BobT
305
309
Hi IGCW,
The leak could be anywhere. The fact that you cannot see any water, and that the pump is "cycling" every 2 hours or so indicates that it is a very small leak. Short term solution is to turn the pump off at the control panel and only turn it on when you need water. Long term solution is to find it!
good luck
BobT
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
basically anywhere in the systema dripping tap may not be noticed but over a period of time will lower the pressure sufficient for the pump to kick in, clean the filter in the pump pressure valve. then check all taps for leakage. Don't forget the waterheater. all pipe connections in case one can be tightened
leak is between the pump and taps, not back to the tank.
Oct 15, 2007
1,622
280
Five Roads Alyth
A class RV
since 2005
...and, any external shower, or any 'tap' throughout the van?
I forgot to purge ours once after a winter empty and the pump ran on, or cycled now and again until the penny dropped, and I'd been in every cupboard with a torch for half an hour looking for the leak:Doh:
11,843
14,080
When the pressure reaches its preset value, the pump switches off and the water is prevented from running back into the tank by a non-return valve, sometimes separate but usually part of the pump. If there is no leakage anywhere (check for a dripping tap) then it could be that the valve(s) are leaking slightly letting water backflow to the tank.
Solution may be a new pump (expensive) or if it otherwise OK just turn it off at night.:RollEyes:
Aug 18, 2008
198
34
Gloucestershire
since Jan 2008
water leak
Yep a leak - we had same problem with pump and sort of ignored it then no hot water - leak was near hot water gas jet - very slow - but stopped jet eventually - sorted now thanks to Motorhome Medics:thumb: in our area but have learnt never to ignore water pump when it goes on its own.:Doh:
Cheers
Jaen
I
igcw9170
22
swansea
think i'll have a look for any obvious leaks, if none found, due to my complete lack of plumbing ability, i'll opt for the turn it off at night choice.
cheers.
Aug 18, 2008
198
34
Gloucestershire
since Jan 2008
leaks
Sorry but you 'probably' have a small leak somewhere and I think pump will burn out eventually.
We were new to motorhoming at the time but so glad we got someone in to check
Cheers
Jaen
I
igcw9170
22
swansea
Dont know if its a coincidence, but I have now been informed by my other half that this seems to have started the night after my son left the washroom tap on and emptied the tank, with the pump still going.
Jul 28, 2010
1,710
617
The world
Small car
I allways turn off the pump when either driving or sleeping if the pipe in the system should burst you will get a lot of water in a very short time and one hell of a mess to clean up
so by turning off the power the pump can not run on
hope this helps
Aug 18, 2008
198
34
Gloucestershire
since Jan 2008
leak
Sorry back again but draining water tank with a tap dripping would eventualy burn out pump. Pump still working means a leak somewhere - turning off pump will not solve the problem. Only trying to help - it could have cost us a fortune if we had left alone.
Hope you get it sorted - we had no idea as not engineers but have learnt so much after nearly 3 years - huge learning curve and without MotorhomeFun:thumb: help:thumb::thumb: could have been a very expensive one.
Over to you and hope you solve problem.:thumb:
Cheers
Jaen and Colin
keith
3,421
1,864
Ecclefechan
Autocruise Starseeker
After owning 5 motorhomes, and every one had this I learned to live with it. Never had a pump 'burned out' and never found a leak.
The worst was the RV since the pump was not fixed very securely and being a big pump it was noisy but never had a problem with it, other than the noise.
Switch it off if it's a problem. if it was a big leak you will soon find it. :Doh:
2,345
10,186
Can also be caused by the hot water tank cooling down..
if no obvious leak , turn it off at night ,
I wouldn't lose sleep over it , these pumps can take a lot of abuse, can run dry and won't burn out, more likely flatten the battery first ...
WynandJean
6,670
3,303
West Midlands
Bailey Autograph 682
I was under the impression that it was usual for the pump to activate now and again just to maintain the status quo. Isn't that why they advise not to leave swithed on unnecessarily to avoid drain on battery?
Wyn
keith
3,421
1,864
Ecclefechan
Cheers
Jaen and Colin
If I empty the tank the pump will not run. ECU recognises the tank is empty and stops the pump running, don't they all do this?
2,345
10,186
Wyn
the main reason for switching off when you are asleep or out of the van is in the event of a bust pipe to prevent the van from flooding ..
aba
2,775
1,112
yorkshire
dec 2009
could be that by emptying the tank you got air in the system.
try filling the tank and systematically run each tap hot and cold to bleed the air out of the pipes
i suppose it could also be a frost prevention valve dripping on the water heater.
andy:thumb:
rhoda
5
Winchester Hampshire
High Top
AFAIK in a pressure demand system (as opposed to pump activation by outlet microswitches) the pump operates on sensing a pressure drop on the outlet side. Therefore there must be a loss of pressure between the pump and one of the taps/shower head/toilet flush ie a leak. The fact that the pump only runs for a few seconds suggests a very slow leak - perhaps just a drip every now and then.
Personally I would switch the pump off when not required (I had to do this anyway for 6 months when I had a cold tap failure in my sink). However, in the boats that I have owned, which all have the same type of water systems, there is always power to the pump and pressure fluctuations are controled by a small accumulator.
Rhoda
