Water pump running won't turn off.
Sussex coast
Lowline
learning
As title water pump running just fired up on its own. But is pushing water into wc.
Luckily I found this before bowl overfilled.
I have turned pump off on panel for time being any ideas
Tap Micro switch stuck closed if it's a microswitch system or micro switch in pump jammed
Hi again its a thetford loo taking flush water from main tank.
Now I've looked and the relay was showing signs of corrosion. Unplug it pump Dosnt run.
Son im assuming its relay. As I replaced this some years back. I went to Halfrauds and thought I matched it but the new one. Dosnt do anything.
So I know need to find a partnumber as to get correct part
If it's an automotive type relay, the blade terminals are usually numbered next to each terminal and some also have a schematic of the relay circuit.
Might be worth having a look to see if the terminal layout is the same for the new and the old relay.
What van is this in, I thought you had a Burstner Delfin ?
