WATER PUMP NOT WORKING (1 Viewer)
MARK JANES
5
europeo 69 p
I HAVE A FIAT DUCATO 2.3 RIMOR EUROPEO 69 PLUS,
FOR SOME REASON THE WATER PUMP AND THE HEATING HAVE BOTH STOPPED WORKING BUT AS THE HEATING WORKS THROUGH A COMBI BOILER I GUESS THIS IS NORMAL IF NO WATER IS COMING THROUGH.
I HAVE CHECKED THE BATTERY AND THE READINGS ARE 12 SOMETHING NOT RUNNING AND 13 SOMETHING WHEN THE ENGINE IS RUNNING SO I HAVE ELIMINATED THE BATTERY I PRESUME.
ANY IDEA WHAT TO TRY NEXT GUYS.
Dec 24, 2014
9,217
47,564
Hurstpierpoint. Mid Sussex.
Compass Navigator
Ever since lighting was by Calor gas.
(No need to shout! ;) ).
Both of your (something :unsure: ) voltage readings seem a bit low, however............
Have you checked the pump fuse?
Is there water in the Combi or has the frost protection drained it?
Does it work on 240v?
M
MARK JANES
5
europeo 69 p
I don't know how to check the combi but the frost protection did drain it but i refilled again.
no it doesn't work on 240v
Dec 24, 2014
9,217
47,564
Compass Navigator
Presumably the sink and basin taps don't deliver water either.
Sounds like deffo a pump problem. Checking the pump fuse is the first step.
There is a potential second issue in that if you tried to run the system not realising that the water had drained the thermal trip may have activated and need resetting.
Jul 6, 2018
200
320
North Yorkshire
burstner brevio t640
Since 2010
Daft question but you did reset the the frost protection and it stayed in the closed position before you refilled 🤔
welcome 😁
faraway
738
604
Kent
Chausson Flash 10
Getting better
Basic question, but is the switch on, on the main panel? I’ve made that mistake when I’ve accidentally bumped it!
WynandJean
6,670
3,303
West Midlands
Bailey Autograph 682
Since 2010
Hello and welcome from West Midlands. 👍
Wyn
raysalaugh
2,256
4,173
Leyland
AT Delaware
since 2010
Hi, Do you know where the pump is situated and if so can you check if it's getting power?
Apr 27, 2016
6,873
7,994
Manchester
A class Hymer
Since the 80s
I think the motorhome heating is supposed to work even if there is no water in the system. The water heating doesn't, obviously. So does the space heating work? Is it blowing air through the vents, is the air cold or warm?
Jun 8, 2019
4,931
18,760
Bexley Kent
Given up Motorhoming
May 2019
Greetings peeps welcome from Bexley it’s cold here and snowing 🌨🌨⛄
