- Nov 24, 2008
- 907
- 2,444
- C Class
- Since july 2009 And Still Going Strong
Seeking advice from the electrical minded out there please.
I've installed a water level sender unit like this,
www.force4.co.uk
And a gauge like this
www.force4.co.uk
All wired up correctly but only says half full on the gauge when the tank is full and float is right at the top of its slider.
Am I missing something?
Do I need to calibrate the gauge? Can't see how though.
Shawn
Wema Stainless Steel Fuel/Water Sender | Force 4 Chandlery
Wema Stainless Steel Fuel/Water Sender. Available to order now with Worldwide delivery. Wema Stainless Steel Fuel/Water Sender - This sender system is simple, with no mechanical moving parts to wear, so it is very durable and can withstand the constant mo
Wema Water Level Gauge | Force 4 Chandlery
Wema Water Level Gauge. Available to order now with Worldwide delivery. Wema Water Level Gauge - An analogue water level gauge ideal for use with the Wema Stainless Steel Fuel/Water sender.• Gauge Diameter: 54mm• Voltage: 12/24V• 0-190 Ω• Colours Availabl
Shawn
