- Aug 22, 2007
- 34,795
- 75,407
- Carthago Compactline
- Since 1996, had Elddis/Swift/Rapido/Rimor/Chausson MHs. Autocruise/Globecar PVCs/Compactline i-138
Yes something like that is an idea as that boiler he is using is under £100I'm not sure if some of the gas boilers can be mounted on their sides rather than upright so this may help routing pipes etc, alternatively just ensure you position it so you can put a 'chimney' on to take it up to the roof within the PVC, it will obviously take up a little bit of space interally but would still allow you to be a stealth camper.
Edit - just found this as an example of what I mean:
Storage and boiler flue - Vandog Traveller
Yeah thats quite pricey tjough for what it is ....the truma ultrastore is cheaper than that one ....and both need a cowl outside
The instantaneous heater in your 2nd link is not a balanced flue so I wouldn't want to use it inside a van.https://rover.ebay.com/rover/1/710-...0001&campid=5338547443&icep_item=303202588857
This could be a last resort fitting ....if i could disguise or colour code the vent/cowl
Or one of these wall mounted with a roof vent
https://rover.ebay.com/rover/1/710-...0001&campid=5338547443&icep_item=353360186200
Thanks ...i didnt know that so that rules that out.The instantaneous heater in your 2nd link is not a balanced flue so I wouldn't want to use it inside a van.
I think the Truma Ultrastore is available in gas only therefore cheaper but you would probably have to source from Germany.
Are you driving about a lot? Some US RVs have heaters that heat the water using the engine. These units are not exactly stealthy, but it wouldn't be rocket science to rig something up with a heat exchanger that worked off the engine coolant. You'd have to time your shower so that you have it just after you arrive there. It would be no good for a morning shower!Ok so ive pretty much decided my next van is going to be a self build ....so at the minute ive been spending time planning a layout and equipment etc.
I want to use a diesel heater and a woodburner for heating but im unsure of what to do for water heating.
As i plan to build it as stealth as possible im looking to avoid lots of vents etc on the outside ...
So what methods of water heating have those with self builds gone for ?
I dont plan to have 240v equipment in the van at all as off grid is the goal ....so lpg, diesel, solar etc
Photos , links , details appreciated.
Also, if you can cope with LPG, then the Whale Expanse heater can be underslung without vents through the bodywork. It goes well with the Propex space heater, which can also be underslung.Are you driving about a lot? Some US RVs have heaters that heat the water using the engine. These units are not exactly stealthy, but it wouldn't be rocket science to rig something up with a heat exchanger that worked off the engine coolant. You'd have to time your shower so that you have it just after you arrive there. It would be no good for a morning shower!
I do miss the old RV, when you could just pull on the handbrake and go straight into the shower!
That could be an option i hadn't thought of ...at the minute i plan around 460ah of agm batteries with 500w solar ....and also a victron 24/12 -30amp b2b charger .Just thought, I have a mains only CAK tanks XT mini water heater which can be run off inverter takes 10mins to provide hot water for shower. This is a small unit very efficient and may work for you even when you are off grid assuming you have an inverter. They also do a version that has an heating coil so you can heat with diesel heater .
Water and Air heating, Propex, Malaga, Heatsource, Malaga, Truma, Whale, Webasto, gas electric 240v diesel cascade carver | Motor-Caravan | Caravan & Marine
C.A.K. TANKS Manufacturers of 250 water tank sizes. Motorhome, Caravan, Horsebox and Narrowboat Interior Equipment Specialist with thousends of products in stock from all the leading brands. See our 90 page mail order catalogue for water heaters, pumps, taps, smev cookers & sinks, fridges...www.caktanks.co.uk
Has to mount against a wall, the flue is on the side of the unit, standard fit 35mm thick wall, 50mm extension available.So the truma is looking like a possibility.
I wonder if it could be vented through the floor?
Because my type of use it seems agm is the best choice .... especially if only charged by solar and b2b
Why would you want to fit crap like that?
Madness they are useless as a leisure battery unless you buy the very expensive professional ones. The AGM's in my last van lasted 18 months.Because my type of use it seems agm is the best choice .... especially if only charged by solar and b2b
Its also a cost issue lol
As it is 2 x 230ah varta are nearly £500
Weight distribution looks a bit one-sided to me.Heres a lovely homebuild with woodburner, and they have a wall mounted boiler with a roof vent .....now i know im possibly in the minority but how homely is that?
Awesome build it even has a washing machine View attachment 459765View attachment 459766View attachment 459767
Gas will be much cheaper than diesel, esp LPG.Trying to avoid a gas fired combi like the truma etc as they are expensive and power hungry
If you have a nice hot fire going, what happens if you get moved on from where your parked.
Something like?46 years ago i had an enamel stove” in the trailer that i lived in, and wrapped around the flu sitting on top of the stove was a stainless water tank, which had a tap, you filled it with water,and the water got hot, it was ingenious, and ive never seen one since,
I have posted this before.Madness they are useless as a leisure battery unless you buy the very expensive professional ones. The AGM's in my last van lasted 18 months.
As you rarely stay in one spot more than one or two nights if you don't want the cost of Lithiums standard flooded cells are probably best for you. I prefer Gel but they take longer to recharge but you can discharge them a lot lower.
Isn’t there an issue with LPG supply locations reducing and especially in Scotland ?Gas will be much cheaper than diesel, esp LPG.
I think you used to be able to get separate water heaters and some heaters that vent from below.
There has been a number of posters on here and to MoHO magazines decrying the removal of LOG pumps from garages, and I understand in the whole of the west coast of Scotland there are only 2 or 3 pumps, I stand to be corrected on those number.Not aware of issues, but haven't been out at all for over a year, least of all to Scotland.
Nothing to stop you using bottled gas, I'm sure it'll still be cheaper than diesel.
